Rust on the Firewall?
Old Feb 19, 2014 | 12:20 AM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
so i just got this car, its a 91/92 camaro convertible. i bought the car knowing it had some rust in an odd place, at least to me. the firewall in certain spots has holes in it, some of it is below where the A/C parts would be toward the bottom and there are a few small holes maybe the size of a half dollar right under the relay farm on the driverside. before i go and patch these holes up ( cut them out and weld in new steel ) what could have caused this? this is my third third-gen and also the newest, i had a 90 firebird and i have an 86 trans am, neither of these had the rust this one has. im just curious on where this would have started, i wanna fix that as well as the holes. ill post some pics hopefully tomorrow when i get some pics of it.
Old Feb 19, 2014 | 08:11 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: Rust on the Firewall?
On my car the seam sealer in the cowl failed. This let water in between the two layers on the firewall, resulting in rot.
Old Feb 19, 2014 | 08:44 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Rust as you described is pretty typical for cars that sat outside, especially near an ocean. Once the drain in the wiper channel were clogged with leaves or something it all starts too rust.
Personally, bad firewall rust is a deal breaker for me. Too critical structurally to ignore and too integrated to fix easily, I'd prob send it to the crusher.
Old Feb 19, 2014 | 02:06 PM
ssj2link's Avatar
Engine: 5.7/5.0
here is the rust, i would prefer not to crush it as i can simply weld in new pieces of steel.
Attached Thumbnails Rust on the Firewall?-imag0294.jpg   Rust on the Firewall?-imag0293.jpg
Old Feb 19, 2014 | 03:21 PM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
Its easily repaired, replace the entire firewall if you have too.
The downside is there is going to be a lot more rust than what you can see in the pictures.
Strip all the areas, find out exactly how bad and proceed from there, Even if you have to cut out half the firewall to replace it, not too bad a job and allows you to do some smoothing or heater box mods and such whilst your at it.
Stealtht/a is correct in leaves/debris being the cause, especially in the first picture, add some rain and moisture soaking in.
Other causes are the internal flap housing for the air inlet direction of the heater, when leaves go in the drain channel, this fills up with water completely, pretty nasty.
Old Feb 19, 2014 | 10:18 PM
ssj2link's Avatar
Engine: 5.7/5.0
thank you guys very much! ill be looking into this on the weekend
Old Feb 20, 2014 | 10:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Yeah I would have to agree that is a easy fix first I would get the rust off the right side to see just how bad it is it looks to be pitted but if it hasnt gone through just get all the rust out and epoxy prime and repaint and on the left side I would look on the inside and see how it is in there if the same as the outside I would cut me a patch panel clean off all the rust and weld it in and be done
Old Feb 21, 2014 | 01:47 PM
nosajwols's Avatar
Car: 82 Z28
Check the floors as well, this type of rust usually ends up in water collecting under the carpet (trapped in the jute)--it did on mine.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
mfp189
Sep 27, 2015 09:25 AM
