First Gen parts compatibility
Old Apr 7, 2014 | 09:42 PM
compted's Avatar
What parts, if any are compatible from first generation Camaro in the body and frame category?
Old Apr 7, 2014 | 10:28 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: First Gen parts compatibility
With out putting much thought into it, I would say none.
Drivetrain parts can be retrofitted. But as far as body and "frame", they're completely different cars. The thirdgen is actually a uni-body.
Can you be more specific?
Old Apr 8, 2014 | 11:11 AM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Having one of each, I think the clear answer is nothing is compatible between the generations. Except the Schrader valve...
Old Apr 8, 2014 | 11:36 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
...all generation camaros are unibody...
That being said, there isn't much that could be swapped in, w/out some retrofitting, from a 1st to 3rd gen
Old Apr 9, 2014 | 03:33 PM
Zooms_82_TA's Avatar
Car: 82 Trans Am
Engine: 355, Dart Iron Eagles, Comp Cam
Transmission: TH350
Axle/Gears: 9 Bolt Posi 3.27
1st and 2nd gen Camaros have sub frames. They are not a true unibody.
Old Apr 10, 2014 | 07:06 AM
Car: 1983 Z28
Our cars have subframes too, hence the term "subframe connector." Having a subframe is an indicator of unibody construction, not a difference. Our subframes are welded in place instead of bolted in (like the early models) but we still have them, because they are all unibody constructed cars.
Do some research on unibody verses body-on-frame construction.
Not trying to start an argument online, just trying to stop the spread of misinformation.
Old Apr 10, 2014 | 07:17 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I would still say the the 1st and second are not a true unibody. They have a kind of front frame that is seperate from the back. Its divided at the firewall. It's a pretty poor piece of engineering actually that usually has to be reinforced. Our cars have a k member or engine cradle like many unibody cars, but the body is one piece from bumper to bumper.
Sub frame connector is a term that came from those older cars for the reinforcement of front to rear parts. I think it's actually incorrect terminology for out cars. We should be calling them "frame rail connectors" or "chassis braces"
Old Apr 10, 2014 | 07:29 AM
Car: 1983 Z28
I see your point, but still don't consider our cars any truer of a unibody construction, maybe a more updated version, but that's all.
I can agree to disagree.
sorry for hijacking your thread, OP!
back to 1st gen compatibility...
Old Apr 10, 2014 | 07:31 AM
stealtht/a's Avatar
How are third gens not true unibody?
They are an early version with certain flaws, true, but definitely a unibody.
I'm not too worried about hijacking this thread, it didn't have far to go at the beginning....
Old Apr 10, 2014 | 07:47 AM
Car: 1983 Z28
I was never saying that thirdgens weren't a unibody, because they are a unibody, clearly. My whole thing is that a 1st generation is just as much of a unibody as a third generation is, and in post #2 it reads like the poster is saying that 1st and 2nd generation camaros were not unibody cars when in fact they were.
The term unibody refers to specifically the body of the vehicle, not the front clip. The fact that you can't unbolt ours like you can on earlier models doesn't make the earlier models not a unibody.
I guess I'm just getting stuck on people saying "true unibody" vs "unibody." I've never heard anyone try to break down a heirarchy of unibody cars within divisions of unibody cars, if that makes sense.
Old Apr 10, 2014 | 08:24 AM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
the first gen just has more of a real frame under it that can be unbolted & can be removed from the body like a full frame car its not part of the body both are unibody just not the same design well my 67 is a backhalf car so actually its not a unibody at all lmao!!!
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
ChevyZ71
Aug 13, 2015 07:30 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
