Flushmount light swap on my 84 t/a
Old Apr 13, 2014 | 02:45 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Decided to finally do this after having the parts sitting around for over a year. Still need to do some fine tweaking, mostly adjusting the headlight housing assembly. This swap fits much better on 82-84 cars due to the boxy headlight bezels in the corners. I am also making up a prototype for a clear looking light setup rather then the blue.
Was going to nightshade these but now I am thinking they go well with the blue decals on the car.
Dusty pics (just pulled this thing out of storage)
Old Apr 13, 2014 | 07:20 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Flushmount light swap on my 84 t/a
The car looks great and it does go well with the blue trim, but do they actually work as headlights? They certainly aren't inspectable.
Old Apr 14, 2014 | 02:30 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
They are about as bright as the stock headlights. Even better with HIDs installed. As for inspection im not sure. The mod can be reversed with an extra set of headlight assemblies to pass an inspection if necessary.
Old Apr 14, 2014 | 06:48 AM
stealtht/a's Avatar
I can tell you for sure they don't pass inspection, but few people seem to care about that, including many inspectors unfortunately.
I'd be less concerned with the brightness vs the beam pattern. Seems like you would have a very limited field of view. How about some night pics?
Old Apr 14, 2014 | 06:57 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I will have to get some. I'll get some good pics once I detail the car for the first time this year. This is the second T/A I have done this swap on. These are driving lights and I found them better at night then the factory set up on my last car.
The original creator of this mod user "Redraif" I believe, may be able to chime in on the swap.
Old Feb 21, 2015 | 12:19 PM
nathan44's Avatar
Car: trans am
Engine: 5.3 l59 flex
Transmission: 4l60e
That's an awesome detail on that car brother. I mean wow.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Omega
Aug 10, 2015 12:46 PM
