Rear window leaking
Old May 7, 2014 | 12:21 PM
pontiacdog's Avatar
Car: '86 Trans Am
Rear window leaking
The rear window on my '86 trans am leaks and I'm trying to figure out how to fix it.
Water comes in from the lower corners, or at least that's how it looks from inside the car. I have applied silicone to the corners but it didn't help.
Previous owner has drilled small holes on the floor so the water doesn't build up inside the car but IMO this is a stupid fix.. I gotta fix the leak AND the floor..
Old May 7, 2014 | 06:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Rear window leaking
Did the weatherstripping ever get changed??
Old May 10, 2014 | 05:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
1) Spoiler to decklid area.
2) Height adjusters/corners too high.
3) Sealant between deck/glass at the edges.
Old May 10, 2014 | 09:31 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
I had a similar leak. Ended up resealing the window to the deck.
Old May 24, 2014 | 12:57 PM
pontiacdog's Avatar
Car: '86 Trans Am
It appears the leak is right here:
http://i8.aijaa.com/b/00312/13288629.jpg
I already gave it a new seal with black silicone sealant. Should I have used something else?
Even after 3 days of drying in the sun it's still a bit sticky and all the pollen attaches to it.
Otherwise the seal works quite well but the fact that it's bright yellow from pollen is annoying.
And it doesn't wash away easily either, and too much rubbing will break the seal.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
pfsteichen
Feb 9, 2016 06:59 PM
69 Six Pack
Oct 5, 2015 07:51 PM
