1991 z28 access panel restoration help
Old May 29, 2014 | 12:50 PM
91zswhitt's Avatar
I'm restoring a 1991 z28. Car doesn't need a lot on the interior but the exterior needs some work. The car has a fuel pump access panel that I'm wanting to restore back to the original as possible. In other words, what is the best what I can make this look like it has never happened?
It has been cut and covered with bondo. I thought about sanding it down and repainting....is there a better way?
I'm just not a fan of the access panel.
Old May 29, 2014 | 01:32 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 1991 z28 access panel restoration help
If you want to take it back to almost like it never happened then drop the tank, cut some donor sheet metal from the cargo portion of a junk yard car (enough to cover the existing hole), and weld it in. Grind it down, paint it, and you'll be good to go.
Old May 29, 2014 | 09:57 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I would get a replacement part from a yard just like RedLeader289 said then fit it to match the hole flush then but weld it in
Old May 30, 2014 | 09:04 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
That just doesn't make sense..you have any pics of it? I'm all for the access door if done neatly but I just don't get why someone would bondo over one? Did they install the super duper life long lasting fuel pump guaranteed to never go bad?
Old May 31, 2014 | 10:10 PM
Engine: LQ4 ls 6.0
We didnt say bondo over it we said repair it the way it should be done
Old May 31, 2014 | 11:54 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
The OP said it was bondoed over.
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
deracer
Apr 11, 2016 12:04 AM
neekolzun
Aug 24, 2015 04:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
