FIX OR REPLACE (CALLING ALL BODYMEN)
Old Jun 30, 2014 | 03:47 PM
IrishGreen's Avatar
Car: 91 Camaro RS
Engine: 5.0 L 305
Axle/Gears: Stock
My son got into an argument with a guide-rail a few weeks ago and this is the result. Blew out both tires. Bent the lower control arm and strut spindle (got that repaired). All that is left to do is the body work along the passenger side. As you can tell the guide rail rolled the lip of the wheel well up. Can this be repaired or should I replace the whole rear quarter? And if so, who is a good manufacturer?
Old Jun 30, 2014 | 04:03 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: FIX OR REPLACE (CALLING ALL BODYMEN)
Not a body expert but I'd try to get that fixed but looks like it's gonna take a little more than bondo and a suction cup to fix that rolled lip as opposed to the other little dents on it.
My Nissan has the drivers side fender rolled and creased a little worse than that from some drunk fool in a SN95 mustang convertible that decided to crash into it when it was parked on the street. I'd like to fix the fender but if the lip is too badly damaged and will cost too much I'd sooner go find a new one at a junkyard and replace the whole fender but of course that should be an easy bolt in and out fender but yours since it's the rear quarter will require cutting it out and welding the new one in.
But I believe a good bodyman might be able to bang that out with a mallet, maybe some bondo/sanding and buff.
My 2nd gen T/A also has the right rear quarter smashed in and I know that will probably require cutting it out and welding a new quarter panel skin in place because it's creased and a little rusty on the surface, Classic Industries sells them but they're kinda expensive. Maybe you can find a cheaper one on ebay or craigslist.
If you want I can get two pictures up later of the damage on both my cars just for reference.
http://www.classicindustries.com/cam.../c2397535.html
Old Jun 30, 2014 | 04:15 PM
IrishGreen's Avatar
Car: 91 Camaro RS
Engine: 5.0 L 305
Axle/Gears: Stock
That would be helpful as a point of reference. Thanks....
This car is completely original and solid. But if it needs a new quarter I will bite the bullet and put one on. Just want pursue all my options.
Old Jun 30, 2014 | 05:12 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
The most damaged area appears to be of the wheel arch. Being that the 1/4 panel yields little structural rigidity, I would see if you could section out that wheel arch with that off another car. The rest of the 1/4 panel appears clearly repairable. I would avoid sectioning the entire 1/4 panel in efforts of maintaining the original corrosion protection, if/when possible.
Old Jun 30, 2014 | 05:28 PM
Yenipenny's Avatar
Car: 92 RS Heritage
It's almost impossible to provide decent advice from one picture...
Based on what I see, I would use the different attachments on a slide hammer to pull out the wheel arch. The rest appears to be normal minor bodywork except.......
That dent on the quarter near the top edge of the door might be a problem. I would have to see other pictures looking down the side to hazard a guess. There's a possibility that the entire quarter panel is pushed in. If so, it will require some heavier pulling equipment than a slide hammer.
Regardless, I wouldn't replace the quarter. The damage is fixable.
Old Jun 30, 2014 | 06:28 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
From what I see I would buy a new quarter panel then cut out the section on both and replace.
Old Jun 30, 2014 | 07:05 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
x2
Old Jun 30, 2014 | 08:47 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I would also replace it but I would replace it with a full panel
Old Jun 30, 2014 | 09:00 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Its hard to say from one picture, but I would rather replace it. A skilled bodyman could probably fix it but thats not always whats best for the car.
Old Jun 30, 2014 | 09:15 PM
Engine: LQ4 ls 6.0
Yeah and not to mention that the outer wheel housing is also bent
Old Jul 1, 2014 | 07:16 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
In terms of a good brand of panel to buy, if you go that route, Goodmark is a trusted brand. I would look for a partial panel off of a junkyard car though if possible.
Old Jul 1, 2014 | 07:37 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Replacing the whole quarter is a difficult job on these cars, even sectioning a panel is difficult. Lots of interconnected panels.
I think that one could be reshaped.
Old Jul 1, 2014 | 07:41 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
From and hours standpoint, it would take me (personally) longer to re-shape that than to section in a new piece. Time=money. I say replace it.
Old Jul 1, 2014 | 11:42 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Sorry If I'm late, I couldn't get better shots but I took what I could since I was strapped for time and my HTC EVO phone is old and it's the only one that can post these since my Apple device cannot copy bb code to paste and post.
From top to bottom
My 1990 Nissan Sentra XE
Pic 1 Passenger side Fender is perfect.
Pic 2 Drivers side is not from being struck by Drunk SN95 Convertible Mustang Cobra/Saleen Driver
Pic 3
Pic 4
Pic 5
Pic 6
Pic 7 - Top view
Pic 8 - Top view looking down at it towards the front bumper which took a little bruise on the impact too but repairable. It's mostly just the fender that took the force. .Thank god the fenders are steel, if they had been hard rubber like the front bumpers are then the force of impact wouldn't have resisted the 30mph Hit from the Saleen/Cobra and the damage would have far severe and gone well into the engine bay and rendered the car useless and totaled. The Car drives like nothing happened, except for that ugly looking Cosmetic bruise on the Fender wheel well and the part of the front bumper that wraps around the side and connects to it.
Old Jul 2, 2014 | 02:52 AM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
Good news! That honestly looks like something you could build yourself out of some sheet metal and weld back onto the car. Use your other side as a template, and it shouldn't be too bad.
Old Jul 2, 2014 | 04:16 AM
Phenom-1's Avatar
Engine: 5.7 TPI
I know I had dozens of detailed pics of the rear quarter on my 2nd Gen T/A to perfectly show the creased damage on the right rear quarter like in your situation on the Camaro but the original micro sd card on my HTC EVO crashed/failed and I couldn't recover the pics. And I tarped up the car to prevent the elements from rusting it any, as it will be awhile before I get into a situation where I can have it restored.
So I couldn't get better pics than this since I tied lots of string around it tight the last time I replaced the tarps but here's the best I could do to illustrate the damage on the right rear quarter panel of the T/A.
1.
2.
3.
4.
5.
6. Still got the Set of Genuine Firestone S/S Radial Tires on it that my father bought for it NEW back in 1985/1986 Fat meaty looking 225/70/15s On the Original 15 X 7 Rally ][][ wheels.
7. What the Rear looks like.
8. What it would look like Restored to it's full Glory.
9.
What it looked like when New.
What it looks like now after not being driven or touched since 1986.
10.
11. Original Splitter Exhaust tips.
12. Original California Pontiac 400ci Damn Gas Guzzler.
Old Jul 2, 2014 | 05:14 PM
lotsabirds's Avatar
Car: 89 Formula 350 Project
Engine: 5.7TPI
Transmission: 5 speed
Being in the industry for 15 years now, I still say its a tough call. More pics would be very helpful.
However, any time I can avoid replacing the quarter, I do. There's no substitute for factory welds, seams, sheetmetal, and corrosion protection. I'd lean towards repairing the area. Even if it meant going on the frame rack with some clamps to pull the lip back into where it needed to be. Doing that would most likely bring the inner wheel well along with it.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
92purpz28
Aug 11, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
