Windshield washer pump makes noise does not pump
Old Aug 4, 2014 | 07:21 PM
EnvoyIROCZ's Avatar
Car: 1986 IROC-Z
Engine: 5.0 4bbl
Transmission: 700-r4
Axle/Gears: 2.73 G80
I have an 86 IROC i just changed the washer reservoir bc it was cracked . now the pump makes noise (like its pumping) but no fluid comes out. so what needs to be replaced????????????
Old Aug 4, 2014 | 07:35 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Windshield washer pump makes noise does not pump
I too have a 86 IROC. and I have yet to find a new washer pump that works. but you could have a plugged sprayer situation. or the hoses could be plugged.or you could have a bad pump
Old Aug 4, 2014 | 07:49 PM
Joe Tag's Avatar
The pumps have a rubber impeller that turns to crap when they set dry for a while. Also, do you have the check valve on it? Does it work right?
Old Aug 5, 2014 | 02:19 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Is there washer fluid in the tank? If it's empty that could be the issue... :-p
Old Aug 5, 2014 | 03:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you've ever used tap water in washer system that could cause plugging due to the minerals in tap water.
Check the rubber hoses for rot/cracks. Check the hoses for holes as well. Especially if you have a rodent problem. For some reason they seem to zero in on rubber washer hoses.
Old Aug 5, 2014 | 06:03 PM
EnvoyIROCZ's Avatar
Car: 1986 IROC-Z
Engine: 5.0 4bbl
new reservoir with fluid think I might of checked that first
Old Aug 6, 2014 | 05:30 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Have tried running the pump without any of the hose connected to it? That way you can determine if the pump is the problem or if the problem is somewhere in the hoses.
Old Aug 7, 2014 | 03:06 PM
Aaron12873's Avatar
Car: 87' IROC-Z vert
Engine: 305 carb
i went to a ac delco auto parts store and they ordered a new ac deco pump for me i think it was $20.00 plugged it in and it took right off. and whoever said the impeller dry rots is correct thats what mine did cause i took the pump apart its really an easy and quick fix
Old Aug 7, 2014 | 10:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The check valve will cause that.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
