Stock hood clearance
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Ok folks,I have a 91 z28 with a 383 stroker and Holley 650 on top of a PCM high rise intake..what's everyone running for an air cleaner? The 14" element that I have doesn't fit under the stock hood..thinking I might have to go with an aftermarket hood..if I do,I plan on going with the ss style hood..
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Stock hood clearance
The old Corvette L-88 air cleaner will give you the biggest drop that you can get from any air cleaner. It's the only way you can run an Edelbrock RPM intake with a factory hood. So if your intake is no higher than Edelbrock's you should be fine.
Car: 1983 Z28
Engine: 385 Fastburn
I have a vortec eliminator high-rise intake, holley 750 carb, and a 14x3 air cleaner with about a 1-1.25" drop base. Wouldn't fit under a stock '83Z hood, had to get a cowl induction.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
7501 AirGap Edelbrock, 1/2" spacer, basic 14" dropped air cleaner under a stock Camaro hood.
If you have a plain stock hood you can cut out a circle shape out of the inner layer of the metal to help clear.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
