upper and lower door hinge
Old Aug 17, 2014 | 12:55 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i went through a couple threads but still not sure
driver door sagging and cutting into rocker panel and creaks and pops when opening or closing, but upper and lower hinges all need replacing. ive looked around and seen a few things i need to buy but no luck with the roller pin on the bottom hinge, mine looks like an egg right now, broke to hell.
basically looking to where i can get all the replacement parts for upper and lower hinges
Attached Thumbnails upper and lower door hinge-door1.jpg   upper and lower door hinge-door2.jpg
Old Aug 17, 2014 | 01:47 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: upper and lower door hinge
Rockauto has a cheap door hinge pin & bushing kit DORMAN 38401.
Top down solution has everything, high quality greasable or standard and the detent roller pin http://www.top-downsolutions.com/Bod...nterior?page=1
Make sure you have or buy the door spring compressor tool.
I recently did mine, here some treads with pics and tips
https://www.thirdgen.org/forums/body...or-hinges.html
https://www.thirdgen.org/forums/body...oller-pin.html
Old Aug 18, 2014 | 07:47 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
hawks has new hinges if you need to replace them.sometimes ,they are too far gone to rebuild
Old Aug 18, 2014 | 08:25 AM
Amaro83's Avatar
Car: !983 Z28
Engine: 355
Transmission: rebuilt 700R4
Axle/Gears: possi rear end
I got mine from Camaro Central. took it to my local body shop and had them do it. I didn't have the equipment to hold the door while it was off. My doors are still off a little, but I will fix that with shims!! Good luck!!
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
