What to do when lower fender bolt holes are gone
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
As with many of our cars, people that didn't know what they were doing would jack these cars up at the lower fender bolt/seam and bend the crap out of them. That area on my car rusted out a while back and I replaced the area with metal patches welded in. I never re-formed the tab that the fender bolts to ( I was 17 at the time, 30 now). I guess I can re-make the tabs and call it done. Have other people run into this and if so, what have you guys done?
Thanks for any advice or tips.
Car: 1987 Pontiac Firebird Standard
Engine: 2.8L V6
Transmission: Automatic
Re: What to do when lower fender bolt holes are gone
I already know that I am going to have this same exact problem when I get started on body work next spring. The previous owner or somebody seems to have used those tabs to jack it up as well. I would think that it would be fairly easy to Jerry Rig something for it though.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Unfortunately I don't have a finished picture. After the 3rd I ground, shaped and painted the repair but here is what I did. Also don't mind my really bad welding.
Engine: LS3
So you essentially cut out the damage and welded in plate to try and rebuild that area?
I may do something similar. I am neck deep in engine bay mods (firewall, wheel wells, etc...) Once that is done, this is the next thing on the list. Just wanted to get a thread rolling so that when I get to that step I can see what some other people have done.
Thanks.
Thanks.
Thanks.
Thanks.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
