Clear coating bare aluminum to protect it... with what?
Old Nov 6, 2014 | 06:02 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Painted up some valve covers for the 'bird but wanted to leave the raised surfaces a bare polished finish.
What can I spray over the paint and bare metal to protect it without changing the color or being obvious?
Also, it has to be heat/fuel resistant obviously!
Ideas?
Old Nov 6, 2014 | 06:13 AM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
Re: Clear coating bare aluminum to protect it... with what?
I did my valve covers,water pump and water pump on an "89" 5.7 and loved it.It tended to darken the alum. slightly.I bead blasted and degreased multiple times and it still looke good 3 years later. I used Duralast clear I got at Auto Zone.
Old Nov 6, 2014 | 07:05 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Darkened is ok. Just don't want it yellowed or anything!
Old Nov 6, 2014 | 11:31 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I clear coated a intake once and it of coarse turned yellow shortly after, I repainted my 502 valve covers and just keep them polished. When the truck sits between shows I smear vaseline on the exposed aluminum to keep it from corroding.....
Old Nov 6, 2014 | 11:35 AM
Yenipenny's Avatar
Car: 92 RS Heritage
Simply use standard automotive clearcoat. If it's good quality, it won't yellow and will easily withstand the engine heat.
Old Nov 6, 2014 | 11:36 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.eastwood.com/2k-aerospray...oss-clear.html
Old Nov 7, 2014 | 06:32 PM
sssuch's Avatar
The best clear coat I ever used is Glisten PC , two part epoxy as clear as water and tuff as nails . Will hold up to heat and will not yellow. From the same people that make POR15 , but unlike POR15 this stuff actually works.
Old Nov 8, 2014 | 06:10 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I like the idea of that Glisten PC stuff, but I don't have means of spraying really. Just used rattle cans to do the covers!
Looking for an aerosol high-temp clear.
mantaguy, did you try the Eastwood stuff?
Old Nov 8, 2014 | 07:10 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
From their website...
http://www.por15.com/GLISTEN-PC_p_45.html
...GLISTEN PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness
So it would appear you can brush it on.
Old Nov 8, 2014 | 07:49 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Oh didn't even pick up on that, nice!
Old Nov 9, 2014 | 03:12 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Or you can just rub the bare parts with polish every once in a while. Then you don't have to worry about yellowing.
Old Nov 9, 2014 | 05:00 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
https://a248.e.akamai.net/f/248/9086/10h/origin-d4.scene7.com/is/image/GanderMountainOvertons/79649_L1?$product$
Old Nov 9, 2014 | 08:46 PM
DynoDave43's Avatar
Interesting. How long does a coating of this product last before you must reapply? I have an aluminum diff cover on the truck that I'd like to coat before winter.
Old Nov 10, 2014 | 10:29 AM
sssuch's Avatar
Dave , cant say about the Shark Hyde, but the Glisten PC I sprayed on My Corvette Rocker moldings looks as good now as it did 11 Years ago when I first applied it. Same with the Clutch cover on My Bike.
Old Nov 12, 2014 | 06:39 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
You can also have them powdercoated clear. I made some tables for my house out of square tube steel, hit them with a scotchbrite pad to scuff them up, and sent them in for powdercoat. They hold up great and look really cool, as you can see the heat sinks where i welded everything together.
It's a durable option if you wanna do it once and forget about it.
Old Nov 12, 2014 | 07:02 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Cool ideas, and I didn't know you could powder clear. That would have been way easier!
Ended up with VHT high-temp engine gloss clear enamel.
Didn't change the color of the blue or the polished surfaces at all!
Followed the instructions and did 3 coats before baking them to cure.
Came out great!
Now to install them... mmmm emissions piping XD
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
armybyrd
Dec 5, 2015 09:22 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
