Headlight motor question
Old Jan 1, 2015 | 10:06 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Evening TGO, and Happy New Year!
I have a question about headlight motors like the title says. My motors were refurbished a couple of years ago and the bushings are fine. I took the bucket apart to paint it and naturally the motor housing too. Well on both LH and RH, the little screws broke. One I managed to salvage and return to a temporary state of working order, but the other I am not so sure about.
Being that it would be more likely to find a 4th gen in a junkyard in my area, I was thinking whether or not 4th gen motors would bolt up to and function with the third gen buckets??
Old Jan 2, 2015 | 06:20 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Headlight motor question
Are you talking about the two screws that attach the housing with the magnets to the housing that holds the gear? If so, those screws are known for twisting off very easily. The easiest fix is just to drill out the old screws and put a new screw and lock-nut through it.
Old Jan 2, 2015 | 10:08 AM
alex722607's Avatar
No the ones that hold the motor to the assembly. And on the one that I was able to salvage temporarily... One of the holes for the gear cover.
One I was able to drill a hole through, the other the drill bit snapped in the hole- had to use a cheap one cause the good one was dull
Old Jan 2, 2015 | 11:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, grind off any remaining screw flush, then center punch and drill through. I include a pair of slightly longer screws and nuts with the TDS 209280 Deluxe Headlight Repair Kit because these screws often snap off their heads due to corrosion from how the headlight motor is oriented.
Call me, I can supply a good used headlight actuator housing LH or RH and screws and nuts.
In case you want to purchase the screws locally instead, they are a 8-32 x 1/2" ss washer-head screw.
Lon Salgren
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
