Light bar mounting
Old Feb 2, 2015 | 01:23 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Light bar mounting
Hey everyone,
Recently had to switch my dash emergency lights to full on mini bar on top of the car magnetically.
The problem I am having is where it sticks. The magnets catch good. but the hang off and look a little silly on tops/hatch. I can open the hatch, goes right under it. I know this car was built to be agile, bu my some fabricating minds may help here?
The bar is 18X12X3. And I am putting it on the one cross between the trunk and t tops.
I will look for a way to maybe adjust the bracket, but for now!
Thanks everyone. Just looking for some advice! I will take better pictures when i get back out
EDIT: Also, the bar does stick on. I drove in 75mph hwy with wind and it didn't budge. Looking for more aesthetics.
Old Feb 2, 2015 | 01:40 PM
1o80b's Avatar
Re: Light bar mounting
What the hell !?!??!
Old Feb 2, 2015 | 01:46 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
? whats that
Old Feb 2, 2015 | 02:37 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Wait......WHY?
Nevermind
Old Feb 2, 2015 | 06:30 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
A better look at my issue..
Just curious on any advice. I'm going to try messing with the bracket tonight
Old Feb 2, 2015 | 08:15 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Looks like a bracket mod will be in order.
If you remove the bracket from the light, and take the feet off the bracket, would the studs on the feet (on the right) fit in the holes for the bracket (on the left)? This would eliminate the brackets, bring the feet closer together to keep them on the roof, and get it lower to the roof.
Old Feb 3, 2015 | 03:28 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
I didn't think about that. Assuming it still maintains its integrity at high speed. I will unbolt it and check tonight.
Old Feb 3, 2015 | 04:00 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Unfortunately it looks like the bolts on the bar are bigger than on the magnet
Old Feb 3, 2015 | 04:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Are you concerned because it shines UP and not straight ahead??
Old Feb 3, 2015 | 04:19 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
No? That's not a concern at all. In fact it shined at the proper angle. Its the feet overlap. Thanks!
Old Feb 3, 2015 | 04:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Why is on the T Top and not back farther on the roof?wouldn't it stick better on flat solid foundation.
Old Feb 3, 2015 | 04:32 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
That's all the space there is and I don't want it interfering with lifting my trunk so its further on the ttop. It also helps with the force of the wind
Old Feb 3, 2015 | 04:51 PM
mantaguy's Avatar
Engine: 5.0 EFI
Aren't you a Fireman or Emergency Response member?I think I read that in a previous post.The only thing I can think of(if you have to use that one) is place it on the T Top roof and use a metal plate for the magnet
Old Feb 3, 2015 | 04:56 PM
mantaguy's Avatar
Engine: 5.0 EFI
Let me do that again,place two additional magnets under the feet of the light on the other side of the glass
Old Feb 3, 2015 | 05:04 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Yeah I'm a firefighter and EMT for the city.
And that's a good idea. I will see about that with using magnets or metal under the glass!
Old Feb 3, 2015 | 05:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
It works,I tried it before I posted.but you better get some strong magnets.
Old Feb 3, 2015 | 05:15 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
It looks like the manufacturer of the bar sells replacement magnet . That'll be the way I go!
Old Feb 5, 2015 | 12:59 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by apie2546
Hey everyone,
Why?
I use strobes in my POV. I'd never put a light bar on the roof.
-- Joe
Old Feb 5, 2015 | 01:01 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Originally Posted by anesthes
Why?
-- Joe
According to Texas statute the lights must be placed at the highest point on the vehicle and must be seen 365 degrees.
And I'd rather have a light bar on top than trying to figure out how to place 5 different lights inside my car and messing up the interior.
Old Feb 5, 2015 | 01:26 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Got a link to the statute ?
-- Joe
Old Feb 5, 2015 | 01:30 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
-- Joe
http://www.statutes.legis.state.tx.us/Docs/TN/htm/TN.547.htm - transportation code
It is also at the discretion of the chief of the department. He said it is in the code however they have the right of discretion as well
Old Feb 5, 2015 | 01:32 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
360 degrees
Old Feb 5, 2015 | 01:34 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Originally Posted by Bob88GTA
360 degrees
Its been a long week lol
Old Feb 5, 2015 | 01:36 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Its cool, just rib'n ya.
Old Feb 5, 2015 | 02:17 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
"(1) are mounted as high and as widely spaced laterally as practicable;"
That doesn't mean they have to be on the roof. Front and rear deck lights would be fine.
I do question if your light bar is legal, based on:
"(2) display four alternately flashing red lights, two located on the front at the same level and two located on the rear at the same level; and
(3) emit a light visible at a distance of 500 feet in normal sunlight."
I guess if your light bar flashes left/right alternating red on the front and on the rear one could argue that it is four lights.
If you were a volunteer firefighter or police officer you would be able to use corner strobes as :
(d) A private vehicle operated by a volunteer firefighter responding to a fire alarm or a medical emergency may, but is not required to, be equipped with signal lamps that comply with the requirements of Subsection (c).
(f) A police vehicle may, but is not required to, be equipped with signal lamps that comply with Subsection (c).
But I think you said you are EMS, so that exception doesn't apply to you.
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Aug 5, 2015 07:57 PM
