What to paint
Old Feb 18, 2015 | 07:58 AM
jesse300mph's Avatar
Car: 1987 Camaro
Engine: 2.8L V6
Transmission: 4 speed auto
What to paint
ok so I have an 87 Camaro that I would like to repaint myself. I have auto collision for two years so I know the basics of painting but we have always used waterborne high dollar paints.
I would like to use my garage to repaint it I would obviously tape it clean it ect. But I am unfamiliar with all of the acrylic paints. what would be the best bang for my buck I guess you could say. I have two filters close to my gun and im using a LVLP gun with a 7 gal 2 hp compressor.
Thanks for reading
Old Feb 18, 2015 | 12:11 PM
WTR388's Avatar
Car: 87 Trans Am
Re: What to paint
https://www.thirdgen.org/forums/body...dy-thread.html
Did it in the garage, used a finishline 4 HVLP and an older 60 gallon compressor.
Sprayed Limco single stage urethane.
If I was just doing one paint job, I would do all the prep and then take it to Maaco and pay for a middle of the line paint job. By the time you factor in paint, equipment, TIME, aggrevation etc it is the way to go... For me, I plan on doing a fair bit of painting in the future so that's why I fronted for the equipment.
There are a few changed I will make for next time.
Old Feb 18, 2015 | 12:19 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: What to paint
I don't think I would attempt spraying a car again with a under 5hp compressor.
Maybe your gun has a lot less cfm requirements than mine but I had to take a few breaks with my 3hp pump, 60 gallon HF compressor.
Do not buy any paint from paintforcars. The car will look like a chalkboard within a year.
Old Feb 18, 2015 | 02:24 PM
WTR388's Avatar
Car: 87 Trans Am
Re: What to paint
My compressor is a 5 horse and even then I had to take breaks to let it catch up, which isn't good for keeping a wet edge as you spray.
Old Feb 18, 2015 | 06:00 PM
craptrman's Avatar
Car: 1988 Iroc-Z
Transmission: 5-Speed
Axle/Gears: 3.45
Re: What to paint
I painted mine in my garage. Came out awesome. I used starting line hvlp primer and paint gun with a 5 horse 60 gallon tank. The paint and primer I used was Summit Racing two stage Flame Red High Solids. Three coats of base and three coats of clear. First time I ever painted anything in my life. No drips and show quality. Took top 50 out of 2100 cars at car show. Be sure to cover everything as the overspray finds its way into every nook and cranny.
Good Luck!
Attached Thumbnails What to paint-antonio-260.jpg   What to paint-antonio-569.jpg   What to paint-antonio-1081-1024x576-.jpg
Old Feb 18, 2015 | 09:38 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: What to paint
Your compressor isn't going to be able to handle a full paint job. I once made the mistake of trying to prime about 3/4 of a car with a compressor similar to yours. It took a long time. If I had been spraying clear and need to keep a wet edge it would have been hopeless.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
