can i attach 3rd brake light to 86 spoiler from 87 spoiler
Old Mar 8, 2015 | 01:27 PM
lethaldomestics's Avatar
On 87 the 3rd brake is under the spoiler. can i attach 87 BL to 86 spoiler with out ruining it? Also i mean the whale tail wrap around spoiler!
Old Mar 8, 2015 | 02:04 PM
Re: can i attach 3rd brake light to 86 spoiler from 87 spoiler
Bump
Old Mar 8, 2015 | 02:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
WHY!!!
Old Mar 8, 2015 | 02:22 PM
Because I would like to keep the 3 BL in the stock position and I have a clean 86 spoiler the only difference is the brake light position
Old Mar 8, 2015 | 02:29 PM
Joe Tag's Avatar
Originally Posted by mantaguy
WHY!!!
Then you'd have two HMSL's? Either that or two holes in the hatch glass. Neither one seems appealing to me.
Old Mar 8, 2015 | 02:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
What year do you have??(car)
Old Mar 8, 2015 | 06:09 PM
<p>Ok I have an 87 firebird. but just found an 86 spoiler in near mint condition . I would like make it work. Has anyone done it</p>
Old Mar 8, 2015 | 06:31 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
The 86' spoiler is the same except the third brake light is in the hatch between the hinges while the 87 has it below the spoiler as long as you have the third brake assembly from the 87' I wouldn't see why it wouldn't work.
mantaguy's Avatar
Engine: 5.0 EFI
A good mint spoiler for 86 is very,very hard to find,it's your spoiler do what you want,but you will ruin it.
Old Mar 8, 2015 | 08:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Hey John,we both responded at the same time AGAIN!!!!
Anyway,won't he have to notch out the bottom of the spoiler to fit the light??
Old Mar 8, 2015 | 08:13 PM
87350gtanj's Avatar
the 87' brake light assembly is some what notched to begin with I think it would work?
Old Mar 9, 2015 | 05:33 PM
what I meant btw by mint is that the spoiler is in good condition which makes it mint hahaha when I get home I'm going to see if I can make it work . If not I will be trading it to someone who can use it.
Old Mar 9, 2015 | 05:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Old Apr 20, 2015 | 12:21 AM
So all i have to do is drill two hole in the bottom of the spoiler to make it work .
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
