hood latch?
Old Mar 11, 2015 | 07:54 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
hood latch?
Hey guys, my project is finally almost done but now I need to find a hood release cable/latch. Any ideas where I could get one or should I just plan on using hood pins?
Old Mar 11, 2015 | 09:26 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: hood latch?
A wrecking yard/pick n pull. Chances are if they have five Third Gens they will have five complete units. They're not real high on the pick list.
The pins I'm using are a precautionary measure.
Other than grasping the hood the latch keeps people from being able to open it without my permission.
Old Mar 12, 2015 | 09:20 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: hood latch?
http://www.ebay.com/itm/82-92-Camaro-Firebird-Original-White-Print-Hood-Release-Cable-NEW-GM-/291049804641?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1986%7CMake%3APontiac%7CModel%3AFirebird&hash=item43c3eb9361&vxp=mtr
Old Mar 12, 2015 | 09:31 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: hood latch?
I kinda of figured a scrap yard, I know when I first got my car the hood never opened without messing with it. So I figured I'd try to just replace it all. That and my cable was pretty tore up haha
Old Mar 16, 2015 | 07:20 PM
Engine: TBI,5.0
Re: hood latch?
I like the one mantaguy posted.
Even though there very common item at the Pick n Pull I doubt you will find one looking that nice.
Old Apr 1, 2015 | 09:38 PM
Kblakney's Avatar
Car: 1991 Z 28
Re: hood latch?
i have one i would sell. i took the factory hood off and replaced with a pin on glass hood. let me know if you are interested, its still on the car. PM me if interested.
Old Apr 1, 2015 | 10:32 PM
bbc632's Avatar
Car: 1990 z
Engine: 383 small block chevy
Transmission: tko 600
Axle/Gears: strange dana 60 4:10
Re: hood latch?
I need the hood latch thats on the hood . The hook part . Thanks
Old Apr 2, 2015 | 09:07 AM
Kblakney's Avatar
Car: 1991 Z 28
Re: hood latch?
I have that also. I can send pics when I get home tonight.
Old Apr 7, 2015 | 09:37 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: hood latch?
The typical issue is that the cable housing deteriorates/cracks after
20 years in the hostile under hood environment. Here's how I renewed mine.
Cut of the crimped on end, then pull the cable out of the housing.
A good bicycle repair shop will have (a) housing in bulk, and (b) a small
thread-on cable retainer, that is used on hand brakes. Cut off the old housing
at the handle, and latch positioner, and remove the bulkhead grommet.
Cut the new housing a bit shorter than the original, cause there's adequate
length to re-route when re-installing. The critical dimension is enough
steel cable sticking out the end, to mount the new retainer.
Carefully drill out the housing remnants, put the bulkhead grommet back on,
and epoxy the new housing into place. If the cable end fray's after cutting
off old crimp-lock, apply enough epoxy, to keep the strands together.
It will be much easier to get back through the housing.
Good luck,
kk
Old Apr 7, 2015 | 10:29 PM
Kblakney's Avatar
Car: 1991 Z 28
Re: hood latch?
is this what you need? If so pm me offer. Thanks
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
