Wondering what this object is in my engine bay??
Old Mar 15, 2015 | 10:06 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Hey all, I didn't really know what to search or where to look so I'm going to ask the question myself....
Does anyone know what this balloon like object is for that is circled in red in this picture? Just dropped my LQ4 in a couple of days ago and I have completely deleted heating and cooling including the A/C ducting... Is this ok to remove or is this a necessity? Car doesn't have air bags or cruise control. Thanks in advance for any responses and I'm sorry for posting without searching...
Old Mar 15, 2015 | 11:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wondering what this object is in my engine bay??
Vacuum reservoir.
JamesC
Old Mar 15, 2015 | 11:27 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Is this object a necessity for my cammed LS swap? Only reason I would probly need it is for brake booster correct?
Old Mar 15, 2015 | 11:56 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
That's for the Cruise Control
Old Mar 15, 2015 | 11:57 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
So since I do not have cruise control, it is safe to remove?
Old Mar 15, 2015 | 11:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's all it's used for,you can remove it
Old Mar 15, 2015 | 11:59 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Alright thank you! I'll go ahead and remove it in that case!
Old Mar 16, 2015 | 06:42 AM
OrangeBird's Avatar
Car: 1989 Firebird
as well as the HVAC ...
While it shares some common plumbing with the cruise control , it's actual function is to keep a source of vacuum to both the cruise control and the heat/ac so that during times of low vacuum (wide open throttle) the HVAC doesn't default to "defrost only" . Our HVAC was designed so that any vacuum failure will cause a default to defrost to prevent a crash due to a fogged windshield . Since the original poster has deleted his entire HVAC system as well as the cruise control , the vacuum storage ball is no longer needed .
Sometimes jokingly referred to as "The Orb of power"
Old Apr 7, 2015 | 10:36 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
OrangeBird gets the "Attaboy" for the day:
for combining tech-info, and giggle-*****, all in the same post.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
-=Z28=-
Aug 17, 2015 07:33 AM
jahblah
Aug 12, 2015 05:54 PM
