Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90
Old Mar 14, 2015 | 07:50 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Firebird question:
Need a bit of help here; The front bumper reinforcement bracket (see attached photo) ... I know this is different for the 91/92 model year.
However would the 82-84 bracket be the same as used on the 85-90 models ?
I know the early style used normal threaded (for nuts) studs at the ends and the 85-90 model years used studs for self threading nuts and I presume this would just be an improvement for the assembly line being able to do them up quicker.
However I own a 1989 and just picked up a 1984 bracket to keep as spare just in case I ever need it; then I started to remember having replaced or swapped this bracket out when years ago I had a 1984 bird that I put the later (85-90) regular (so Firebird/Formula) front bumper on; but can't remember why I did mess around with that bracket.
So in short is that bracket the same and can be used on any 82-90 model Firebird or did they change (and if so what changed) in 1985?
Looking to powder coat the 1984 bracket I have however if it wont fit my 1989 I don't want to waste the money doing it.
(picture is one I found on ebay however help to clarify which one I'm talking about).
Attached Thumbnails Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-bracket.jpg
Old Mar 14, 2015 | 12:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90
The P/N will be stamped on it on the left side up top.This P/N is from my 86 TA spare Facia
Old Mar 14, 2015 | 12:55 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Yep however I suspect that is the part number for just the middle piece and would be the same for all years as the end pieces are spot welded on that middle piece making up the complete assembly and a different part number.
I will dig around in my parts books.
However still interested if someone either got both to compare or done a swap and for sure know they are the same or not.
Appreciate the help.
Old Mar 14, 2015 | 07:37 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
From what I remember 82-84 is by itself just like 85-90 and of coarse 91-92.
But you could be correct with the only difference between the 84 style vs 85 style is the way the hardware is used speed nut vs threaded nut since up to 90 they used parking lights next to the headlight assemblies.
Old Mar 17, 2015 | 08:51 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
If anyone got the 85-90 bracket loose and could take a couple of similar photos like these (of the 82-84 style I got hold of) we can compare and see what the actual difference might be.
Photos show the right hand side (passanger side) of the bracket.
Attached Thumbnails Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8387.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8388.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8390.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8393.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8394.jpg
Old Mar 17, 2015 | 08:53 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
And a few more ...
And the info from the GM Parts and Illustration Guide ...
82-84
Group 1.263 # 10017789
85-90
Group 1.269 # 10182097
91-92
Group 7.831 # 10118418
Attached Thumbnails Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8399.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8402.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8404.jpg   Firebird Front Bumper Reinforcement bracket 82-84 vs. 84-90-img_8406.jpg
Old Mar 17, 2015 | 02:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
I took some pics of the two I have, the dirty one outside is the same P/N as my ORIGINAL White one inside.They are Identical(reinforcement bar)the dirty one I have no Idea what year it's off.My Parts Catalog says the same as yours,10017789 for the 82-84,but my White one is from my 86 and it's the original one. I think it's a typo,I'm almost positive that those welded ends have no P/N.there part of the bar.EDIT My parts book actually doesn't list this info for 82-84 it was for something else just on top of this info.
Old Mar 17, 2015 | 02:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
The only difference between yours and mine is,yours uses SAE thread nuts and mine uses Speed nuts.There was 2 different reinforcement bars used for 85-87.
Old Mar 17, 2015 | 07:53 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
I used an '89 bracket on my '84, there seems to be a slight difference where it meets the front fender. It doesn't sit perfectly flush. Nothing really shocking.
The original bracket had been cut for a KR nose and only the side pieces remained, but I threw them away long ago.
Old Mar 18, 2015 | 05:33 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Thanks guys, this is really helpful to clarify the difference.
SolarGoldRaptor ... this confirms what I suspected hence the difference in the end pieces spotwelded to the large centre piece. Looking at the pictures there's clearly a difference in the "step down" between the upper and lower fender mounting points which means the softw bumper cover have to be slightly different in thickness in those areas as the fenders are identical ...
So will be looking at finding the 85-90 version to keep as spare for mine ... not an easy task on this side of the pond as they are rusted out most of them ...
Again thanks for all the help with pictures etc. much appreciated.
Old Mar 19, 2015 | 05:18 AM
Well, if you ever come to the north of France, we could swap them ! Mine is in excellent condition, but the slight difference bothers me a bit. I'd much rather have an '84 piece, but 82-84 specific parts are extremely hard to find here.
Old Mar 19, 2015 | 08:28 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Would be more than happy to swap, if you are in the South of England (or any friends of yours happen to travel over here) let me know and I'm happy to meet up somewhere. Unfortunatly due to the size it's not practical to ship :-(
Regards
Jan
Old Apr 7, 2015 | 10:29 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
My experience is that the fenders, at the bumper cover mounting points
are NOT identical across multi years.
(And I can post pics to support that assertion.)
The key issue is that the contour of the mounting bracket brace,
shown in mantaguy's pics, MATCH the fender mounting point contour.
If not, the mis-match can sheer off the bumper cover mounting tab.
(Go ahead, ask me how I know this. )
Good luck,
kk
Old Oct 30, 2015 | 10:06 AM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Does anyone know the size speed nut for the later model studs? I can't find anything locally that works, and I'd love to get mine fully attached. Part numbers would be awesome, but general size will help me too. Thanks!
Old Oct 30, 2015 | 04:41 PM
mantaguy's Avatar
Engine: 5.0 EFI
The stud itself is 1/4" on my 86.
http://cimg3.ibsrv.net/gimg/www.thir...eda3a00627.jpg
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
kitt23
Aug 15, 2015 12:37 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
