Paint code for 1987 Norwood Floor Pans?
Old Mar 15, 2015 | 10:01 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
I'm going to have to do some floor pan repairs due to an over zealous unskilled welder installation of sub frame connectors by the prior owner of my car. I have clean floors in a parts car that will be donating to the project but would like it to look factory when completed.
Does anybody have the code for the factory floor pan paint? Am I correct in assuming it's the same for inside and under the car?
Thanks!
Old Mar 15, 2015 | 01:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Paint code for 1987 Norwood Floor Pans?
I would assume they are the same color as the car.
Old Mar 15, 2015 | 01:40 PM
PurelyPMD's Avatar
Engine: LB9
No, they have overspray on them that's the color of the car but they are a grey 3/4 gloss, from what it appears to me. I can post pictures later or tomorrow to show.
Old Mar 16, 2015 | 07:48 PM
PurelyPMD's Avatar
Engine: LB9
Not mine, I stole this pic from battman's thread but you get the idea.
Does anyone have the code for the grey that's under that black overspray and on the interior of the quarters, floorboards, etc.?
Old Mar 16, 2015 | 11:50 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
That should be factory sealer and over spray is were they painted the car with the same paint that painted the car its just a gray sealer
Old Mar 17, 2015 | 06:08 AM
PurelyPMD's Avatar
Engine: LB9
I know, does anybody have a paint code for it or will I just need to get it scanned and have one made?
Old Mar 17, 2015 | 01:45 PM
mantaguy's Avatar
Engine: 5.0 EFI
http://paintref.com/cgi-bin/colorcod...on=moy&rows=50
Is this what your looking for??
Old Mar 17, 2015 | 05:20 PM
PurelyPMD's Avatar
Engine: LB9
Unless I'm wrong that just lists the paint codes for the body of the car - I'm looking for the paint that's under that - the primer if you will or sealer coat.
It's the grey color in the picture I posted that has the black overspray on it.
Old Mar 17, 2015 | 05:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yea,that was paint codes.I don't know,Maybe it's some kind of rust inhibiter or Primer GM used.Try Eastwood,they may have something
http://www.eastwood.com/paints/rust-...tml?color=1035
Old Apr 2, 2015 | 08:01 PM
82tarecaro's Avatar
I always thought the grey was factory E coat. You will more then likely need to experiment with colors to get it close as it is not a paint and no code exists. I would guess if you use a grey paint with a bit of flattening agent mixed in you should get the sheen. But you need to probably have the color custom mixed.
Old Apr 2, 2015 | 08:17 PM
Engine: LQ4 ls 6.0
I would just use DP40 its a gray-green epoxy and it close to what you have
Old Apr 19, 2015 | 08:22 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
If it's the grey color you're talking about that's Elpo primer. Get yourself a couple of cans of Pontiac ralley II wheel paint. It's the same color. I'm talking about the paint for the inside wheel, not the outside.
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Amillionoh7
Aug 7, 2015 01:24 PM
