Metro or soft seal need to choose soon!!
Old Mar 26, 2015 | 12:41 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Ive used metro before on my 87 and they fit fine… thick as hell and need to close the doors kinda hard still. Not too happy with the hard top roof seals and they back seals (by the rear quarter don't even touch the windows! So I got new doors and Im looking at getting new seals yet again for them.
Im honestly looking for a cheap decent set. I just need the door seals, outer sweeps, and the triangle seals for the window at the front corner. I'm looking at saving a few bucks going with AM auto parts, 1Aauto or summit. All are within 10-20$ of each other.
If I go with summit Im looking at Softseal for the doors and sweeps and OER for the triangles. OER are cheaper than soft seal at summit… but for like $8 more I can get the soft seals if they are better than the OERs.
AM auto parts I'm looking at metro/house brand for everything. BUt they do have OER style for like an extra $20 for the door seals.
1Aauto will prob be all metro as well.
I know there is a ton of info but I can't get a definitive answer on what to get… the soft seal and metro are close in price… so its more about fitment and quality. What do you guys think?
Old Mar 26, 2015 | 01:03 AM
Car: 87 TA clone
Re: Metro or soft seal need to choose soon!!
For what its worth using the same non OER style seals (except for summit with the OER triangle seals) I'm looking at these total costs.
Summit = $170 (soft seal sweeps,door seals and OER triangles)
AM auto = $180 (Metro everything)
1Aauto = $201 (metro everything)
If I swap out the triangles for soft seal at summit price goes to:
summit = $175 ( everything soft seal)
So is soft seal better than OER on the triangles?
Old Mar 26, 2015 | 09:35 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I used the softseal door seals on my 1985 Z28 and they did not fit well. Where the front of the seal meets the window pillar seal the fit is garbage. The back isn't bad, but it isn't good. I even put new ttop seals on from Softseal at the same time and the fitment is no good.
Old Mar 27, 2015 | 01:20 AM
Car: 87 TA clone
Ah crap, I wonder if the OER style us worth the extra $10 Over the standard metro stuff.
Old Mar 28, 2015 | 07:08 AM
82tarecaro's Avatar
I used Soffseal on my t tops and I like them. They fit and seal well. You have to make sure, with any seal, that the install is correct. There are some good write ups on here. Do your research before installing. Stay away from OER seals.
For the door seals, I used Fairchild and I liked them. The edges have a plastic cage like the originals, so the screws do not just go through the seal.
Old Mar 28, 2015 | 10:40 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I used Metro, had no problems, like 82ta says, You have to make sure, with any seal, that the install is correct. There are some good write ups on here. Do your research before installing.
Old Apr 2, 2015 | 10:09 AM
1Aauto's Avatar
Former Sponsor
If you have any questions about our weatherstrip seals, you can shoot me a PM too and I'll help you out.
We include free shipping and a lifetime warranty on our weatherstrip.
Tony
Old Apr 3, 2015 | 08:49 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I've used soft seal on a different vehicle before and the fit was tight. I chose metro this time but have not installed yet. One observation is the metro does not have the reinforcement inside the molded ends like the factory ones did. I'm sure it will work but will likely require more adhesive and probably some taping to hold place until the adhesive cures. But these are nice and soft!
Old Apr 6, 2015 | 09:59 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Ok I installed the metro door seals this weekend. Since they don't have the reinforcements getting the ends right it's a little tricky. I had to stretch the ends and tape them in place. There factory screws are only useful as a placement aid and to hold the ends. It took working them around quite a bit. While the ends were taped in place I shut the door. I was not pleased about the amount of effort required to shut the door. Very tight. After opening and closing a few times to verify it was as good as possible I left it shut overnight. The next day I took off the tape. Be careful here cause the seal will tear if the tape is strong. Which it has to be to hold. Anyway overall it seems alright. The door shuts tight but the seals do seem to be relaxing and it is acceptable. Not as good as factory deals but hey they're about a third of the price so all in all good.
Old Apr 11, 2015 | 12:49 PM
Car: 87 TA clone
Yea Ive used the metro before So i know how they fit. Ended up going with metro only bc Ive used them in the past and know they will fit but require a lot of time to break in.
Old Apr 11, 2015 | 04:50 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
After a week the door seals have settled in and are just fine. With the Windows up it takes a little follow through to close the doors but not bad at all. I think I would rather have them a little tight now. Along with rebuilding my hinges the car rides so much better than before. Very pleased and the price of the metro seals vs gm they're a bargain.
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
bjpotter
Oct 4, 2015 07:48 PM
