Z28 Black headlight buckets
Old May 11, 2015 | 07:31 PM
deeznuts94's Avatar
Car: 1991 RS/1991 Z28
Engine: 305 TBI/350 TPI
Transmission: 700 R4
Axle/Gears: 373
I recently purchased a 91 Z28. The front bumper and fenders need body work and paint. What kind of paint are you guys using to do the black in the headlight area? Its not flat and it isn't really shiny either. Thanks in advance for any help
Old May 11, 2015 | 07:38 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Re: Z28 Black headlight buckets
SEM Flat black will do it
Old May 11, 2015 | 07:46 PM
deeznuts94's Avatar
Axle/Gears: 373
I kind of want to use the correct stuff. Is that what the body shops would use to do them?
Old May 11, 2015 | 11:00 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
they wouldn't use a spray can they'd use whatever paint products they're shop does buisness with and just do them in flat black. even though they should be semi gloss.
Old May 12, 2015 | 11:14 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Don't use spray paint and make sure it gets clear coated. Mine from the factory didn't appear to have a clear coat and I never found a product I liked using on them. When I painted the car I used the same black I did the top half in. Gloss black with a clear, looks good. I wouldn't worry about the exact color unless you want a real stock spec restoration. That category can be hard to get in at a car show, very strict. Go with whatever you like, some guys on here say plastidip flat black looks great.
Old May 12, 2015 | 05:33 PM
steveo346's Avatar
Car: 91 Camaro z28, 1968 c10
If you want a quick remedy, until you actually take the bumper to a body shop to get worked/painted. Any simple semi-flat rattle can spray paint will work. Just make sure to tape everything up, and give the current paint that you be painting a scuff with a scuff pad.
finished product
Still need to do the passenger side one, but weather hasn't been cooperating in south Texas.
Old May 14, 2015 | 07:01 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Why is everyone saying flat black? They were originally a satin black. There should be a slight reflection, but not full on gloss.
Do a search of the History forum and you'll get pretty good suggestions for a perfect match.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
diana227vegas
Jul 8, 2016 12:27 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
