is there a sealer for the trans am body kit?
Old May 16, 2015 | 11:32 PM
mhatfield 14's Avatar
Car: 87 trans am
I just finished with my trans am today and after all the work I had to do with the rust behind the body kit I don't want it to happen again, now j bought the car just recently but in northern Michigan u never know how the weather will be. So I was just wondering if anyone has used like a sealer between the body and the kit to keep moisture from getting in
Old May 17, 2015 | 08:42 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: is there a sealer for the trans am body kit?
No, you can't keep water out if you drive it in the rain.
The gfx pieces have holes to drain, but they get clogged with road stuff.
The main cause of rust behind the gfx is the steel brackets that hold them on. They aren't painted so they rust which eventually transfers to the body.
Best thing you can do to prevent rust behind the gfx:
Make sure paint on body is in good condition
Make sure the gfx have the plastic tabs that hold the bracket and seperately it from the outside of the body
Makes sure mounting holes are well primered and painted.
Paint the retaining brackets
Use rubber washers or silicon sealant between the nuts and inside of body
Old May 17, 2015 | 09:20 AM
Car: 87 trans am
Thanks for the information, I had to make new brackets and painted them with paint also used stainless steel hardware, but thanks for the info
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
