where to find moldings
Old May 17, 2015 | 01:45 AM
ronchic's Avatar
Car: 1986 firebird
Engine: 305 v8
Transmission: auto
Axle/Gears: 2.73 ?
trying to find 1/4 molding inserts for my 86 firebird . metal pieces are ok , just need the inserts that slide in. i call them bodyside moldings , some call them belt moldings. need them in black , thanks for any help !
Old May 17, 2015 | 08:34 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: where to find moldings
Having a hard time figuring out what you are looking for.
The rub strip that goes down the side of the car on the crease? No metal in that.
The metal backing to the ground effects pieces?
Old May 18, 2015 | 02:12 AM
ronchic's Avatar
Car: 1986 firebird
Engine: 305 v8
Transmission: auto
Axle/Gears: 2.73 ?
not a trans am , body side molding halfway down dr,fender & 1/4 . usually color keyed to car. mine are a metal body and a hard vynl inserts slides into them most 3rd gen have them except for trans am. vynl piece is about 1/4 in thick .metal channel pop riveted to body. , thanks for responding , ron
Old May 18, 2015 | 08:03 AM
stealtht/a's Avatar
Ok, the side mouldings or bump strips were on all third gens, including trans Ams. Many people like myself think they look better without them .
The factory strips are 1" plastic/rubber glued directly on the body line. They are painted body color and installed on top of body paint so they can be removed carefully and leave painted body.
I'm pretty sure there were never any factory mouldings with a metal support or only 1/4 " so yours are added on. If they really are riveted on, that sux.
Old May 18, 2015 | 10:06 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
He must have the aftermarket/dealer installed body side bang strip
moulding.
They rivet on a metal channel and insert a color keyed rubber/plastic
strip they cut from a roll of the stuff.
Seen it time and time again back in the daze of my auto dealer employment.
Usually done by a traveling installer who does everything from vin etching,
pinstripes, auto starts, etc.
Your best off tracking down one of these guys at your local dealer.
Early third gen factory body side moulding/bang strips were just stick on
rubber pieces.
My 84 has RPO B84 for black bodyside moulding
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
tglennon11
Sep 23, 2015 05:30 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rjcme
Sep 5, 2015 01:23 PM
