Gas tank swap
Car: '89 Formula
Engine: L98 350
Gas tank swap
Can anyone tell me if the 6 cyl gas tank is the same as an 8 cyl tank. My 350 tpi tank is leaking and I want to replace it with a factory tank. Hoping to have more availability if it will.
Tks
Tks
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Gas tank swap
According to the parts book 89 used different tanks for the 6 and 8 cylinder cars.
6cylinder used P/N 12509205 and the 8 cylinder used P/N 12509285,I don't know what the difference is.But here's were It gets confusing, for 85-87 they used the 1 tank for both 6cyl.and 8cyl.(LB8,LB9) P/N 12509205 witch is for the 6 cylinder in 89.Same thing for 82-86 They also used the 6cyl.tank
Re: Gas tank swap
I had a similar problem with my tank leaking from the filler neck on my 89 TTA. I ended up replacing it with one from my 91 Firebird (previously 3.1L V6). Didn't notice a difference and the gauge still reads correctly in the 89.
Engine: 5.0 EFI
Re: Gas tank swap
The 91 V6 used the same tank as the V8 and the 89 TTA used the V6 tank, So I would imagine that they'll all fit each other. Their is no explanation why these tanks have different P/Ns.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Gas tank swap
You pretty much have it. I've pulled tanks out of V8 cars, and out of my V6 car. They are all the same. The only one that's different is the 1LE tank.
Car: '89 Formula
Engine: L98 350
Re: Gas tank swap
Thanks for the info. I'm trying to find a '91 or '92 tank for the baffles. Sounds like I can use a 6 cyl. Been looking for a while so maybe adding the 6 cyl tank to the search will make one easier to find.
Tks
Tks
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Gas tank swap
What about a plastic 4th gen tank? Don't they fit, too? I was contemplating a swap to one for my Formy...
Car: '89 Formula
Engine: L98 350
Re: Gas tank swap
Nhra, Is there a DIY or a write up on the swap somewhere? I've done some searching and found that the tank fits fine, the issue appears to be ohm related in the sending unit. I haven't found the solution to the sending unit issue yet. There was also some question about a canister that's on the plastic tank that isn't on the 3rd gen tank.
Any additional info you can provide will be much appreciated.
Tks
Tks
Re: Gas tank swap
Tks
Tks
As for the sending unit I used a unit from a grand prix I believe, which is the same style/connector plug as the 4th gen fuel pump/wiring, but has the correct ohm resistance as the 3rd gen gauge.
AkDrifted
Aug 17, 2015 07:45 PM
