Fuel Pump Cutout Blues (by Previous Owner)
Old Dec 13, 2015 | 04:44 PM
2012sergen11's Avatar
Car: 1987 Trans Am
The 87 GTA I am working on had some hackjob repairs by the PO including cutting out a HUGE area to replace the pump instead of dropping the tank
I am not sure if I am going to keep this car yet and redo it but I would like to know if anyone has experience in fixing the brace that the PO cut during his "repair"
Does anyone have any experience with this and how would I get back any lost structural integrity of the body?
Thanks in advance
Old Dec 14, 2015 | 04:19 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: Fuel Pump Cutout Blues (by Previous Owner)
Wow, that's quite a hack job. Dangerous too with the questionable wiring and the tank essentially being inside the car now. That said it looks like the brace is mostly intact with the spot welds drilled out. To fix it right would mean removing the tank and welding a new plate to the brace. Quite a job if you're not able to do the welding yourself. In the meantime I'd avoid smoking in the car...
Old Dec 14, 2015 | 04:39 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Geez, why did they cut the hole so big? I don't mind the access door method but you only need to cut a hole maybe a third of that size. I'm sorry you have to deal with that.
Old Dec 14, 2015 | 05:17 PM
Car: 1987 Trans Am
Yea idk why they cut such a large hole either. The brace is actually cut so would i need to use another brace when I weld in a new panel?
Old Dec 14, 2015 | 05:29 PM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
THATS MESSED UP.
Old Dec 16, 2015 | 03:45 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
If you keep the car, weld it up as it is your safety at stake. I checked this on last car before buying....it is a deal breaker for me if it is cut.
Old Dec 29, 2015 | 03:04 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
I've seen that a few times. I just wonder if those are done by DIYers or some hack shop that doesn't even tell the car owner.
bryan623
Nov 28, 2015 10:25 PM
bryan623
Nov 27, 2015 12:49 PM
LilJayV10
Nov 26, 2015 02:02 PM
Galaxie500XL
Nov 24, 2015 02:12 PM
Jonny45
Nov 24, 2015 12:48 PM
