Why are paint guys so flaky/picky?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Why are paint guys so flaky/picky?
Car: 89 GTA
Engine: 5.7 TPI
You should look up the guy that painted his car with tractor paint. Looked pretty good and didn't cost him a crap load to do. Though I feel your biggest hurdle is the body work. A crease in the metal is no laughing matter. Is it a front quarter or rear?
Car: 1989 Formula 350
Axle/Gears: 3:23
Only problem I've hit with the Macco Fast Food style paint shops is the fact the car doesn't drive. I'm going to finish up the bodywork myself and drag it in there. Sounds like I'll have to be at their beck and call to be available to move it.
I get that part... its a real PITA when you can't just hit the key and move it...
My shop won't paint anything that someone else did the bodywork on. A non professional doesn't know how to do it correctly, the welds may not be strong enough, the metal could rust, the filler could crack, ect. I've seen it a few times. Bodywork done by a non-bodyman won't be up to the bodyshop's standards. If the bodywork is done poorly it will reflect badly on the shop that painted it. A non-professional might apply the product wrong and it could fail. Also if I don't know what primer is on it, it might react badly with the sealer. It could wrinkle up as soon as you spray it on, or it could fall off in a year. Plus PPG doesn't want us to spray its product over any non PPG primer so it can't be warrantied.
Also, people who aren't in the profession aren't great at gauging what 'minor bodywork' is. The guy I bought my car from told me it had a minor dent on the door. and the fender. It turned out to be waaay worse than that. If you have a 2 foot crease in the quarter you need moderate to major bodywork.
If you walked into my shop tomorrow I wouldn't be able to tell you any of this. I'd be afraid of sounding rude, of you taking it the wrong way and telling people about your bad experience. I'd bet thats why your just getting the short answer and being shooed out the door.
Body shops won't cut corners to save you money. Have you asked them why the estimate is so high? I'm sure they'll give you a reason.
Axle/Gears: 3:23
This is the reason you're having trouble finding someone to paint your car. Your prep work (filler, if i'm reading this right) is a liability for the shop, and the crease you mention could be much more of an issue than you think. I'd like to see pics of this car and the crease/replacement roof panel.
I'll post a couple pics of the body work I need done
Axle/Gears: 3:23
These are my three areas that need work.
I really had no idea this thread would blow up like this... guess there's nerves on both sides
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
After seeing so many bad paint jobs from professionals around here, friends who had terrible experiences, flakiness of shops that will only spray fresh new pieces, and not being able to afford to get the work done by someone else, I tackled the work myself. I bought the compressor and paint gun second hand, not the cheapest, but what I needed. The paint products I found them on eBay, good quality, not the cheapest, but definitely not the most expensive either.
It took me a while, a bit of trial and error, but I learnt so much. There are a few issues, but I'm the only one who sees them :
So if you have the room, the time and the tools, just do it yourself. It IS a tedious process, especially bodywork. The hood of my car had some terrible oil canning, it took me months to get it as straight as possible with the least filler necessary. You have to be very meticulous, making sure you clean before applying every coat.
Painting is the easy part. Clear coat is a bit tricky, you need a spray gun with a large nozzle since it can't be thinned too much. I didn't have that and had a lot of orange peel as a result, it took me a while to wetsand it smooth and polish.
In the end, it was well worth the effort.
Axle/Gears: 3:23
Yours looks great!
That's the stupid part. I have the giant compressor, driers etc.. I've got a regular gun and touch-up gun...top feed style HVLP... I have all of the equipment.. And I've painted cars before... it was 20+ years ago, so I don't even count that as experience... I'm just a little short on time and space. I ordered up the paint etc... I figure its going to end up costing me about $500-750
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I restore cars and paint them and its not all fun and games. and 700 in materials is not gonna cover it when you figure in high build primers and sand paper and everything else that goes into a paint job. I usually have materials bills between 1500-2500. And dont forget the hours. I am doing a flat black job with door jambs and charging 2500 to paint it. thats 55 hours at 45 dollars an hour with minimal body work.
everyone want to talk about how they dont want a show job when you are talking about price but as soon as the car is put back together everyone is a 10 point inspector. so save your bullshit! My sprayguns alone are worth more than 5k and dont get me started on all the rest of the tools i have to buy to make cars look better than new.
you posers think you can put together a small block chevy and you have the world by the *****, but painting a car and having it last more than 20 yrs takes a little more work than the average guy is willing to do.
so you say you dont have time, i hope it is because you make alot of money! and if so should not mind paying someone 70-100 an hour with over 100 hours of labor to finish your car the right way
and by the way it does not even look like a third gen so you need to post this whinny **** on someone elses site
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Rent a compressor and buy a cheap harbor freight gun. Rig a spray booth in your garage. Paint can be bought at NAPA. Paint isn't that hard. Just need to practice a little before you do the car , use an old fender. Most of the 5k paint job is the prep you have already done. If you make a mistake somewhere sand it out and paint it again.
Axle/Gears: 3:23
I've got a compressor, drier, filter and the mid grade Eastwood guns. Eastwood Single Stage Electric yellow. Funny you should mention it, I've got a left over fender that I'll practice on. Its got the same PPG Epoxy sealer that the rest of the car does.
Car: 86 Firebird
Engine: 305 SBC
There you go. I could see 4k for a shop paint job if they strip and fill and sand etc. Lot of skilled labor in that. But you can get a nice paint job doing it yourself too for a lot less money. In your case, you already have the tools and some experience.
Car: 86 Trans Am WS6
Engine: 383 stroker
I built a "garage booth" once and - as a novice - painted this 86Z for under a grand',... ( obviously my labor ) and that includes new door seals, new Fairchild window seals, and used T-Top seals.
After Pic: ( this is when I sold the car )
Before pic: ( this is how I got the car )
Going with Single stage means you will not be dealing with any Clear-Coat expense or issues. Just lay the single stage on thick ( overall ) and then wet-sand forever !!
Car: 1983 Z28
Engine: Carbed 305
The single biggest problem I had while shopping for a painter. No Motor meant that 1/3 of the shops I spoke with said no and walked away,........ Then I mentioned "stripes" and only got 1 or 2 shops even give me any quote at all.
Cheers
Thanx MM ! It's the first and only Blue IROC I ever had. It was a cheap E-Bay single stage and I was a bit worried it would be too light (I did NOT want a baby-blue IROC !! )
And Thanx to you too Don; Although the interior was pretty nice in this after the restoration ( Grey Firebird door panels, Grey Leather 4th gen seats ) the engine was just a re-freshed 86 "roller" 86 LG4. Not enough 'nut' under the hood to compare to the COTM competition !! Yes - I called that 86 LG4 engine a "roller" ----> because I had to roll it end-over-end up the yard to get in in my garage so I could rebuild it !
I do still have a couple 85-90 Front spoilers,.. but no more 91-92's left. Feel free to send me a PM when your ready & I'll get some pic of them for Ya'.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I used all PPG products, the best they had. My total for materials was closer to $ 1,500.00.
The PPG "OMNI" could be a option for some.
I found this chart on the web. Kind of give you an idea of what's taken into consideration.
Car: 1983 Z28
Engine: Carbed 305
My chin spoiler is the 82-84 Z I can buy a new one for not too bad, but im seriously considering swapping the front end for a later year model. Something that will still work with the rest of the cars GFX. Ive never been big on the early 82-84 Z28 front nose unless we are talking about sport coupes from those years. Those were my favorite cars hands down. I would trade my Z for a clean 82-84 sport coupe with NO gfx in just as good of shape any day.
Engine: 6.0L LY6 (Vortech Supercharged)
Transmission: Tick Performance T-56
I love that paint guys are so full of themselves that they think tech college = 120$/hr.... Lol ok...
Axle/Gears: 3:23
[/QUOTE]
Yeah, little more elbow grease but easier to re - do a section if I need to.
[/QUOTE]Yeah, little more elbow grease but easier to re - do a section if I need to.
