help!!!!!!!!!!!!!
Old Feb 3, 2016 | 08:38 PM
missysz's Avatar
help!!!!!!!!!!!!!
i need someone who can give me some info on installing inner fender deflectors on my 1991 z28 camaro any help would be greatly appreciated
Old Feb 4, 2016 | 10:46 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: help!!!!!!!!!!!!!
What exactly do you need? If you're referring to the plastic pieces that cover the gap inside the fender over the front wheels.There's not much to them, they're held on by push pins on the fender side & screws on the wheel well side.
Old Feb 4, 2016 | 07:09 PM
missysz's Avatar
if i put them on is it gonna rub my tires when i go to turn and such seeing how i have 18"rims
Old Feb 4, 2016 | 08:52 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It may, depends too on how wide your tires are.Its almost impossible for them not to rub.Even with stock sizes there is some rubbing issues.Mine have holes rubbed thru on both rear portions.
Old Feb 5, 2016 | 02:07 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The size of the diameter of the wheel is not the problem.
Putting the wrong size tire on that wheel would be the problem.
Concerning the overall diameter .
Now, how wide the 18 inch wheel is can play a roll even with the right size tire on that wheel.
B4C5.7
South East Region
Apr 3, 2016 05:20 PM
B4C5.7
Jan 28, 2016 09:34 PM
gta_knight
Jan 26, 2016 12:29 PM
B4C5.7
South East Region
Jan 23, 2016 09:12 AM
NWFreerider
Jan 19, 2016 02:39 PM
