Side trim
Old Dec 25, 2001 | 06:42 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Side trim
Where do you buy that side trim that runs down the door and an inch on the fender and 1/4 panal? I have the thicker version not that black trim, its the kind painted body color
Old Dec 25, 2001 | 11:33 PM
Drew's Avatar
GM is the only source for the correct factory pieces. Be prepared, they aren't cheap.
Old Dec 26, 2001 | 02:14 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe you will have to paint them. From the factory new they were molded in body color. Both of my 87's are solid yellow. But when you buy them from a dealer, I am pretty sure there all one color.
You might be better off going through the junk yards, bring a puddy knife & peal a few off.
John
Old Dec 27, 2001 | 12:00 AM
Drew's Avatar
The GM pieces should be available in the same color, but keep in mind some pieces probably arent available anymore. Keep in mind if you go searchign for used door edge guards, the finish oxidizes the same as paint, if they aren't waxed regularly the paint will wear off.
1992 Trans Am
May 10, 2023 07:19 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
