Replacement for T-Top Channel Edge?
Old Jun 1, 2016 | 10:11 PM
jdhh74's Avatar
Car: 1984 Trans Am
Engine: L69
Hi all,
I have a 1984 Trans Am. The plastic edging on the T-Tops is cracked and breaking off at the front, inner corners of both T-Tops. These pieces are part numbers 20192915 (front) and 20192546 (center) from GM. They aren't being made any more and the only NOS pieces I found were $50 per piece.
Does anyone know another place to get these or an alternate plastic channel that could be used and is more affordable?
I'm including some pictures - with a red line to highlight the strips I'm talking about.
Thanks - any help or hints is appreciated!
-John
Old Jun 2, 2016 | 08:21 AM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: Replacement for T-Top Channel Edge?
subscribed-I'm curious.
Old Jun 2, 2016 | 02:57 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
That's going to be a tough one as I don't think they used the perimeter trim past '84. I always thought it was dumb that they stopped using them, it's the only thing you can grab that's not 300 degrees in the Summer. Oddly enough they put huge ones on the 4th gens, and also all glass t-top Corvettes before then. If someone finds a source with a reasonable price, I wouldn't mind retrofitting them onto my '91.
Old Aug 7, 2020 | 08:35 PM
Larry Alvarado's Avatar
I have same issue and am researching now. Looking at plastic channel sized to fit and also door edge protection- plastic material glued on.
Will check back how it goes and what I use.
Old Mar 23, 2021 | 04:30 PM
jonny_sanchez99's Avatar
Car: 1991 camaro z28
Engine: SBC 355
I've been looking for some aswell but can't seem to find them anywhere...
FueledSoul
Jun 21, 2012 01:03 AM
Q's 91z28
Oct 3, 2010 03:21 AM
Psycho139
Interior Parts Wanted
May 15, 2010 11:59 AM
BlueZee28
Aug 18, 2009 12:38 AM
92FormulaBird
Jul 9, 2009 05:04 PM
