oil carter dent
Old Aug 3, 2016 | 08:35 AM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
oil carter dent
hello
please look at this. I have some sort of dent on the oil carter (hope this is the english name):
Is it normal or is it the result of some bump?
thanks!!!
Old Aug 3, 2016 | 08:38 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: oil carter dent
Oil Pan...and no, it's not normal. You must of hit something.
Old Aug 3, 2016 | 06:10 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: oil carter dent
I second that. We call it an oil pan in the U.S. and it does look like you ran over something.
Old Aug 3, 2016 | 10:40 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: oil carter dent
not normal,but very common to be dented and no problem
Old Aug 4, 2016 | 08:25 AM
NiG's Avatar
NiG
Engine: 5700cc
Re: oil carter dent
thanks!
I bought the car that way. Apparently, it doesn't cause any problem. I have some oil drops sometimes, but nothing scarying. They told me not to change anything, because... the engine is running ok
Old Aug 4, 2016 | 09:35 AM
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
Re: oil carter dent
If the oil pressure its ok it shouldn't matter.
Oh and in Europe the term "carter" is used when you order gaskets for the lower part of the engine ...that's oil pan ,oil pump ,o ring for crankshaft and so on.I'm pretty sure its a english word but not used in US.
Fast92RS
Aug 9, 2015 05:38 PM
YoungMoneyVII
Jul 13, 2009 07:41 PM
Zokal
Nov 2, 2007 04:47 PM
gogie123
Sep 2, 2006 08:05 PM
wa90formula350
Nov 6, 2000 08:37 PM
