1992 firebird ground effect
Old Sep 3, 2016 | 04:02 PM
Dustin Hinton's Avatar
hey guys, i removed all my ground effects on my bird, but there is a piece of metal that sticks out alone the side that the plastic ground effects attaches too, What do i need to take this metal piece off at the bottom of the door?????
Old Sep 3, 2016 | 05:56 PM
russ&dars t/a's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
Re: 1992 firebird ground effect
You have to remove the door panels to get to the nuts. Then you might want to fill in the mounting holes.
Old Sep 3, 2016 | 06:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That piece is welded to the body, you will have to cut it off. The earlier cars it was removable and just screwed on
Old Sep 3, 2016 | 10:30 PM
Thank you, i cut it off with a cut off wheel, but i dont know of a way to un weld the pieice off my car, unless a pay someone a $1,000 dollars to do it, but im not doing that, so any ideas?
Old Sep 3, 2016 | 11:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Its probably spot welded on, could partially drill out the spot welds and chisel it off. Then grind the wed area smooth.
No where near a 1000$ dollar job. But ill do it for 999$
Old Sep 4, 2016 | 02:29 PM
thank you 86ta, $9.99 is a awesome price, but NJ is to far
Old Sep 4, 2016 | 03:12 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
It is spot welded a lot of places the whole way on the underside. if you can see the weld spots you can use the cut off wheel in those spots and carefully grind the spot weld out
Ezrider83
May 10, 2016 03:10 PM
wiskerchen019
Apr 16, 2016 05:38 PM
789roby789
Carburetors
29
Apr 9, 2016 08:09 AM
Veaceonee
Mar 18, 2016 04:56 PM
J's86ROC
Aftermarket Product Review
Nov 11, 2001 09:29 AM
