Rocker Panel / Pinch Weld Rust
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Rocker Panel / Pinch Weld Rust
Wire brush.
Rust neutralizer.
Paint.
Large ball-peen hammer for whoever smashed the pinch-weld.
Rust neutralizer.
Paint.
Theres a hole in the pinch as you can see!!
How about cutting and replacing the metal?
Will it be hard to do?
Car: 86 Trans Am WS6
Engine: 383 stroker
I just did this on my trans am, I had the exact same hole. heres my thread
https://www.thirdgen.org/forums/inte...-interior.html
Post #'s 33 and 41 show the kind of cutting I had to do. what you cant see is that I straightened the pinch with vice grips, wire wheeled the rust, rust neutralized, and painted it over. then obviously I welded in new metal and seam sealed and painted
Thank you a lot, there is the exact pic i was looking for!
What welder should i use in order to weld it good? (I wanna go cheap)
Engine: V6 2.8
Two basic problems with cheap welders:
1. Poor penetration of the weld.
2. Likelihood that the rod/wire will "stick" when the arc is struck badly.
Quality welders are expensive for a reason.
Cheap welders are reviled for the same reason.
At a minimum you need a 30 amp outlet to plug a cheap welder into.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
https://www.amazon.com/Lincoln-Elect.../dp/B000QFNZ74
Engine: 383 stroker
Go with a gmaw mig welder. for body work like this, using shielding gas is way better than flux core wire.
Everyone says stay away from harbor freight welders but at least there's a store near you that you can return/exchange if a problem arises, it's a different story with all the other cheap Chinese welders on the internet. Obviously if you can get a used miller or Lincoln electric for a good price that is the way to go.
The lincoln I posted is only $320 on amazon and is a mig welder. althoug for some reason this site keeps changing it to a walmart link
I live in Italy and here houses got 220v
So Shall I go for a MIG 20/30 amp welder?
Engine: V6 2.8
Check the manufacturer's specs on the welder you are considering.
Be sure your outlet is rated for the manufacturer's power-requirement spec.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I am fixing that exact spot now. It isn't hard, it is just a pain because the floor is there.
Also, you don't need much of a welder since you're only doing sheet metal. You'll likely blow through it if you don't practice first.
