New Engine; Old Speedo
Car: Red 05 Viper SRT 10 & Yellow 03 Z06
Engine: 87 Camaro - 355 TPI Custom
Transmission: 5 Speed BW World Class
Axle/Gears: 3.73:1
Hey, any ideas how to reset the odometer on a speedometer? Or where I can get a new speedo for a 1988 Camaro with 00000 on the odometer? I hate to run a new motor and have a mileage on the speedo.
Your best bet is to remove the tumbler, disassemble it, and carefully reassemble it at 00000. Rolling it back won't work. Then you need to put a declaration sticker on your drivers door stating that the odometer has been modified, and listing the current and new readings. Check your state laws for the particulars.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's a violation of federal law to modify your speedo. Just because your car has a new motor doesn't mean that the rest of the car doesn't still have those miles on it.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
THE ONLY time that I know of to actually mess with the Odometer that it MIGHT be legal would be if you changed Speedometers, then you might have to. I adjusted my odometer to the correct milage when I changed speedos because my orginal TRIP Odometer was malfunctioning & was un repairable from wear. So I changed Odometers too (corected though).
beachrodder
Aug 7, 2015 04:27 PM
