Windshield Wiper Arm Replacement?
Old Jan 20, 2017 | 07:22 PM
That Sky Guy's Avatar
Edit: For all future readers, this is fixed by tracing the tube down to the base and removing them by pulling firmly, separating the tubing without dissembling the whole grille portion.
I am trying to replace my windshield wiper arms. I managed to replace the arms, but I don't know how to replace the tubes connecting to the washer reservoir.
What do I do to fix this?
Last edited by That Sky Guy; Jan 21, 2017 at 05:10 PM. Reason: Knowledge acquired!
Old Jan 20, 2017 | 09:44 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Windshield Wiper Arm Replacement?
Are you talking about the rubber tubes that transfer the fluid?
If so bring a small amount to an auto parts store and get a few feet in bulk. Should be cheap.
Old Jan 20, 2017 | 11:49 PM
I have new arms to install, and the tubing is attached to the old ones. I'm asking how I remove the grille/plate to get to where the tubing runs, under the arms.. unless there's a way to do it without removing the grille or plate.
Old Jan 30, 2017 | 10:10 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
These grills/plate?...see arrow/note in windshield...
Old Jan 30, 2017 | 10:11 PM
zero13's Avatar
Car: 91 Z28
sorry,text came out so small...but red line shows the part you are referring to?...
Old Jan 30, 2017 | 10:12 PM
zero13's Avatar
Car: 91 Z28
sorry text ended up so small..the red arrow points to part you are referring to?.....
Old Jan 31, 2017 | 02:40 PM
Yes, at the time that was the part I was talking about... but I've since edited the OP with updated information.
Thank you for responding!
