Power Antenna
Old Dec 30, 2001 | 02:51 AM
nagga's Avatar
Power Antenna
i have an 84 Z28 with the standard antenna, i have also a power antenna from an iroc, not sure what year, but is it possible to just hook it up in my car?? any help would be appreciated
Old Dec 30, 2001 | 04:54 AM
Blue502's Avatar
It'll work, I think you need to run the antenna's power lead from the radio so that it retracts when the radio is off.
Old Dec 30, 2001 | 09:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe a relay is also required. Check the audio board.
JamesC
Old Dec 30, 2001 | 11:19 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
From 82-88 the parts & illustration guide sais there all the same. looking at the 89-92 90% of the parts seem to be the samy anyway.
I converted my formula over to a power Antenna, and here is what you need out of your donor car.
> the Power antenna & all the brackets (obviously)
> the cable from the radio to the Antenna ( they atach differently)
> A power wire from the radio to the antenna relay on the interior of your car. (pink I beleive) then there are the 3 wires that go from the relay to the Power antenna.
>You will also have to run a wire from your fuse block to the Relay.
When I did mine, I was in the middle of converting over to TPI. The donor car was wired for the power antenna, so that made my job so much easier since I just replaced dash wiring anyway. It was all there.
You might have to get creative. For the wire going to the relay it needs to be unswitched to the ignition. Otherwise when you turn your car off the antenna will stay up. Im thinking its the wire should be Orange, but it could be a yellow wire.
John
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
