Inner rocker (and floor) replacement with Subframe connectors installed?
Old Mar 2, 2017 | 03:52 PM
WTR388's Avatar
Car: 87 Trans Am
I'm doing my inner rockers and full floor pans later this month. I installed BMR subframe connectors a few years ago.
How much of an issue am I going to have welding in the inner rocker and the portion of the floor pan that goes along the rocker?
Am I better off to take the time/mess of grinding the subframe connectors off?
This turned from me doing just the center of the under body to me pulling the entire car apart. I'll be pulling literally everything but the windshield and dash out of the car.
Decided I'll fix the one small rust spot on my drivers inner fender, re-locating where my LS swap harness enters the fire wall and re-organizing that harness to hide the wires as much as possible, and clean up/protect the underside rear of the car.
Is it worth my time to build a rotisserie like robguitargod1 did?
I'll be using epoxy primer and rubberized undercoat for the bottom of the car.
Old Sep 2, 2022 | 08:30 AM
CaptainThirdGen's Avatar
Car: 1988 Formula
Engine: LB9 305 TPI
Transmission: 700r4 w/ Shift Kit
Axle/Gears: 3.23 Posi
Re: Inner rocker (and floor) replacement with Subframe connectors installed?
I know this thread is old (sorry). Was curious how this ended up working out for you.
I have a few thirdgen projects with similar rot. Im concerned that they may be too far gone. Im not willing to give up on them quite yet though.
Tidan
Feb 23, 2021 06:56 PM
balloonfoot
Convertibles
Jul 21, 2012 01:31 PM
86WS6
May 21, 2012 07:42 PM
Mathius
Jan 14, 2004 04:47 AM
TwinTurboROC
Oct 16, 2003 09:23 AM
