3rd gen window sweeps
Old Apr 15, 2017 | 08:54 PM
88irocjoe's Avatar
Hey guys...new guy here. Bought an 88 IROC last spring. It's overall pretty good shape. Usual wear parts are definitely worn out...replacing things as I find them. Todays question...yes...there will be more!!!!....ordered and received the inner window sweep for left door. Outside is immaculate.
I noticed the original is stapled in and thought maybe the new one would come with hardware ...but it didn't. What have you folks done in this situation?
Old Apr 15, 2017 | 09:48 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Re: 3rd gen window sweeps
Let me know what you come up with. That is my next project on my GTA.
Old Apr 22, 2017 | 05:59 AM
Bluestreek's Avatar
Car: sold
Curious too.... shop about to install mine... we noticed the top of the door trim inside sweep is attached to the plastic trim by what appears to be a method of where the factory used heat to melt the little plugs into like a tac head, securing it. The replacements don't have these plugs to melt... looks like small bolt and screw is only option?
Old Apr 22, 2017 | 06:31 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
How about aluminium "Pop" rivets? I used them on my 79 Trans Am and 88 Lincoln mark VII LSC's window sweeps.
Old Apr 22, 2017 | 03:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I used these from 1A.
https://www.1aauto.com/1982-92-chevy...=329665&y=1986
Old Apr 22, 2017 | 06:35 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I used,....... staples. Usually the large copper colored staples like you'd find on large ( fridge, stove ) cardboard box. Just clamp the new weather-strip to the plastic panel with a few little clamps & use a tiny drill bit to drill holes for the replacement staples. Push the staples thru with your fingers and bend them over - done. Add a staple to each plastic panel mounting "TAB" that touches the new weatherstrip.
It's been awhile since I did this, but I seem to remember that it's a PITA to get the original staples out. IIRC I used a pair of wire 'snips' and a small flat-head driver to un-bent the old staples so the could get pulled out without destroying the plastic.
