87 Trans Am Roof Rust Crack
Old Apr 28, 2017 | 04:12 AM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello Guys
My car has, on both sides of the roof corner, those rust cracks.
How could I repair or weld them? Is this hard to do at home?
Old Apr 28, 2017 | 09:21 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: 87 Trans Am Roof Rust Crack
More photos would be helpful -- I've never seen cracks there, although rotted channels in front of those cracks are pretty common. Is there any other significant rot like that in the roof? How are the channels? If it's that rotted in other places, it might be easier just to cut the whole roof off and weld in a replacement from a donor. Although now that I see you're from Italy, finding a donor car over there is probably not an option.
Old Apr 28, 2017 | 10:05 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It can be repaired if you are talented with a welder. Best bet would be to get it all cleaned up and take more pictures with some farther away to get a better idea of the whole situation
Old Apr 28, 2017 | 10:06 AM
Front channels are rotted
Rear channels alternate fromm good to rotted
Finding a roof here is impossible or very very hard
I will take some pics and post it
Thank you in advance
Old Apr 28, 2017 | 11:17 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Grind\Brush\Clean
Fabricate new pieces and weld them in. Or weld in a backer and build it up with weld and aluminum\flexible body filler (since this area can flex).
Old Apr 28, 2017 | 02:28 PM
I claeaned all the stuff there and that's what i got: seems an hard weld because the metal is thin
The rust seems located all here.
I guess the body cracked and then rusted with years
Old Apr 28, 2017 | 02:53 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Is that body filler in there? Almost looks like someone tried "fixing" it at some point.
The only way to truly fix it is to weld in new metal. If the metal is too soft\thin to weld properly, then you'll need to cut it back to a point where the metal is in better shape and then weld in new metal.
Old Apr 28, 2017 | 06:20 PM
Yes, all the t-top weatherstrip rails were fixed with bondo.
I will order new ones from metalfabrications soon
Old Apr 28, 2017 | 07:30 PM
NoEmissions84TA's Avatar
Being in Italy, I don't know if these help you, but
http://www.ebay.com/itm/82-92-Camaro...RYhq3k&vxp=mtr
http://www.ebay.com/itm/82-92-CAMARO...pWVjJ3&vxp=mtr
Old Sep 8, 2017 | 03:11 AM
thank you guys I rewelded everything and repainted the car.
Metalfabrication Design helped me a lot
Old Sep 8, 2017 | 10:34 AM
navy02ws6's Avatar
Glad it worked out...be sure to post some pix when you get it back and cleaned up!
Old Nov 26, 2017 | 11:06 AM
Those are the pics
Old Nov 26, 2017 | 03:24 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Mine was similarly cracked though not as bad. I welded them up before I repainted but 6 months later they had recracked. I've been told with a good set of subframe connectors they probably wouldnt have cracked again. Something you should consider...
Old Nov 26, 2017 | 04:47 PM
absolutely! I am planning on welding alston ones
