Rolling odometer foward.
Old Jan 2, 2002 | 12:45 AM
RSRagtop's Avatar
I recently bought a low-mileage gauge cluster for my 91' RS. I want to make the miles the same on my new gauges. I need a faster way than driving 100,000 miles ( I'm a busy guy ). BTW, the cluster is still out of the car if that helps. Isn't my cars speedo electric, not cable driven. Can I just swap the little drums?
Old Jan 7, 2002 | 03:58 AM
89camaroRSV6's Avatar
my word of advice... leave elec speedos as it is...and mech speedos are a pain..
dont open it up... cos there are too many gears and alignement issues involved....
drive it as it is and be happy..
Old Jan 7, 2002 | 01:05 PM
RSRagtop's Avatar
Each guage is seperate in a 90'-92' Camaro cluster, right? Can I just swap complete speedos? My old speedo is nice my other gauges were fubarred thats why I bought the new cluster.
Old Jan 7, 2002 | 06:33 PM
the gauge is a modular design...
u can remove each one induvidually,.... but i wouldnt adviceu to do that ...
if i were u i would go with the complete better lookin one...
i know 89 is diff from 90-92
90-92 ive seen the same type
so see if all gauges in a cluster are workign fine and fit it...if not just try replacing one of them first ... dont open it up totally'
and i lost my temp gauge ... and i said what the heck and bought a mechanical temp gauge (2 1/16) and fit it in my gauge pod) gives me a betetr reading and more relaible...
good lock man try it though..
Old Jan 7, 2002 | 09:49 PM
RSRagtop's Avatar
Actually my tach is gauge that is broken, I guess I could just swap tachs.
Old Jan 8, 2002 | 04:33 AM
yeah just swap the tach
the tach is diff depending on a v6/v8
some of htem have diff redlines... thats about all
good luck
Old Jan 8, 2002 | 11:56 AM
RSRagtop's Avatar
Yeah, I bought the right one, took me while to find it.
Old Jan 8, 2002 | 12:08 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am not sure about the camaro ones, but my firebird, all I had to do was replace the Odometer unit. there was only a few screws to change it. The hardest part was poping out the reset button for the trip Odometer. (lemme explain: My trip odometer did not work, so I had to replace the unit, I re-set up the numbers for the correct milage on my new odomoeter. The reset button on the replacement one was bent, my onld one was fine, so I just replaced the pieces that were messed up...)
Matter of fact the electronic driven odometer assemblies are all the same for firebirds. It would not surprise me to find out that the Camaro ones are the same for 90/91 & 92 as the firebird ones, but they proabably are different.
hope that helps... I should do a tech article...
John
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
