C&C tops
Old Jul 23, 2017 | 08:59 AM
BradOpp's Avatar
C&C tops
Hey everyone, I'm trying to figure out what parts are different from a C&C t-top setup to a factory setup. (i.e. seals, the tops themselves, headliner, etc.)
Old Jul 23, 2017 | 09:40 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: C&C tops
Everything, nothing in common at all
Old Jul 23, 2017 | 12:45 PM
BradOpp's Avatar
Re: C&C tops
I know, I'm looking for a list of everything
Old Jul 24, 2017 | 09:07 AM
stealtht/a's Avatar
Re: C&C tops
Not sure what you are looking for.
The c&c ttops have NO common elements with factory they are different in every way.
Old Jul 24, 2017 | 11:57 AM
BradOpp's Avatar
Re: C&C tops
I know the t-tops themselves are different alkng with the headliner, and pillars, I'm wondering what all, outside of the t-tops, are different. What all else did C&C make different from the factory cars
Old Jul 24, 2017 | 12:23 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: C&C tops
Everything!
Everything they used is different from factory. There are no common parts in/on the car or the tops that interchange between the two.
I don't know how those who've already responded or I could make that more clear.
Old Jul 24, 2017 | 12:36 PM
BradOpp's Avatar
Re: C&C tops
I understand the T-Tops and it's pieces are not at all the same, what I'm asking for are the other pieces, like, are the pillar covers the same as factory or not, I know the headliner isn't a factory t-top headliner, obviously C&C didn't build their own car from the ground up so where does their changes stop, cuz it's not just the T-Tops, that's what I'm asking.
Old Jul 24, 2017 | 02:05 PM
rgauder's Avatar
Car: 1987 Trans Am
Re: C&C tops
They were a different size (x & y) than factory, so everything associated with them is different.
Seals, trim, headliner as previously stated, all different.
Old Jul 24, 2017 | 02:12 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Re: C&C tops
They took a hardtop and cut two openings for the t tops. The associated trim pieces to hide the cuts are of their own design or were modified pieces.
Old Jul 25, 2017 | 06:32 AM
PurelyPMD's Avatar
Engine: LB9
Re: C&C tops
The screws/fasteners that held in the a- pillar trim pieces were the same as were the clips that held in the headliner.
Old Aug 30, 2017 | 09:47 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Re: C&C tops
As stated, the C&C tops are a different size. They cut out the roof and riveted in a frame. They used a hardtop headliner and cut out the ttop sections. The A pillar trim pieces are hardtop ones that were trimmed. The caps at the top of the A and B pillars are unique. The seals are also unique. Order from Hawks or sunroof doctor. There is also a front and rear metal trim piece on the roof that is unique.
