i was looking around for new wheels from my trans am, i am running the gta 16s on front and back, all 4 are fronts. what looks best for running corvette C5 z06 wheels? fronts 17x9.5 and rears 18x10.5 or both front and back with the 17s? i want a clean look, my car is totally stock suspension wise, and i know i need to run spacers with these wheels but what size spacers? thanks
I think it's 2" spacers all around.
I think I'll be doing theses wheels as well, 17" all 4 corners.
what size tire should i go with? 255 wide is what i have on the back with my 16in GTA wheels.
89firebird
close
I went with 17X9.5 front and 18X10.5 in the back in C7 Z06 wheels. In my case I had a slight clearance issue in the front with the tie rod. So I had to get an aftermarket tie rod that would clear the rim. If I had known ahead of time I probably would have gone with an 18X9.5 up front. Not sure if the C5 wheels will present the same clearance issue.
2" spacers should be correct.
can i see what the C7 wheels look like on the car? ive been also thinking about possibly doing thoseOriginally Posted by 89firebird
I went with 17X9.5 front and 18X10.5 in the back in C7 Z06 wheels. In my case I had a slight clearance issue in the front with the tie rod. So I had to get an aftermarket tie rod that would clear the rim. If I had known ahead of time I probably would have gone with an 18X9.5 up front. Not sure if the C5 wheels will present the same clearance issue. 2" spacers should be correct.
89firebird
close
89firebird
close
The last picture is after I lowered the car a bit. The factory ride height was just a little to tall for my taste with the new wheels.
wow those look really good, im going to be buying lowing springs ( https://www.summitracing.com/parts/eib-4-0138/reviews/ ) so they might not work
89firebird
close
I think lowering springs would work fine. I went with Ground Control Weight jacks so I could adjust the ride height and not have to guess where a lowered spring would set it. As long as you get the right springs there shouldn't be an issue.
This is what I'm running now, stock suspension
89firebird
close
Looks really good!
how much were those ball park? and thank you!
89firebird
close
Here's the ones I bought: https://www.oewheelsllc.com/18-Fits-...0-5-17x9-5-SET
I also ordered blank center caps and had a local laser engraver put the bird logo on them.
i might look into those thank you!
now you said you needed a new tie rod with these wheels, i may go with 17s all the way around so what one did you get? also what size tire are you running on the front
