EARLY VS LATER TRANS AM STEERING WHEEL QUESTION
Old Apr 12, 2017 | 08:59 PM
JimRockford's Avatar
Hi, I have a 1988 Trans Am, and unfortunately for whatever reason Pontiac decided to ugly up the steering wheel that year. I was wondering if I would be able to use an 87 or earlier Firebird or Trans Am steering wheel on my 1988 Trans Am steering Column without any issues. If I recall correctly there is a thick plastic collar on the back of the 87 and earlier Trans Am steering wheels.
Old Apr 12, 2017 | 09:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: EARLY VS LATER TRANS AM STEERING WHEEL QUESTION
does yours look like the one on the left?
Old Apr 13, 2017 | 09:18 AM
Yes sir! Exactly like that one
Old Apr 13, 2017 | 12:40 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I put the 1984-87 style wheel in my '91 T/A with no problems, can't think of a reason why it wouldn't work in an '88.
Old Apr 13, 2017 | 04:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
I see no difference's in witch the way they will be installed,it should fit right on.
Old Apr 13, 2017 | 06:54 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
the back plastic on the older steering wheels is longer than the newer wheels, and the sleeve on the column was different also. Not sure on 88, but on my 91 I had to trim the wheel for it to fit.
Old Apr 13, 2017 | 07:11 PM
That was my concern. Thanks for the input
Old Apr 13, 2017 | 08:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
The top one is a early version and the bottom is what you have.
The later is less than 1/4" higher than the early version.
