hinge kit
Old Jan 5, 2002 | 05:59 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
hinge kit
does the door need to be removed to replace pin and bushings in lower hinge?
Old Jan 5, 2002 | 06:01 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
No,
But the spring can be a bit of a bugger.
Cheers
Richard
Old Jan 5, 2002 | 09:16 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The easiest way I have found to do this is to open the door. Then support it somehow. Cover the big spring with a shop cloth and pry it out. Be careful this spring can and will hurt you. Remove the spring clip/retainer and drive the LOWER hinge pin out. Now remove the kick panel from the interior. Remove the bolts that hold the LOWER hinge to the body, and remove the "body side" part of the hinge. Remove the old bushings from the hinge, install the new ones. Do not hammer them in! Use a 5/16 bolt and nut with a few washers as spacers to slowly pull the new bushings in to place. Now put everything back together. You may need a special tool to install the big spring.
Thanx,ANDYZ28
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
