Hood Struts for use w/ fiberglass hood?
Old Jan 6, 2002 | 04:09 PM
Camaro350TBI's Avatar
Anyone know where to find the hood struts to use w/ a fiberglass hood? I need this for my '88 Camaro.
Old Jan 6, 2002 | 06:38 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
You should be able to get some at auto zone. If not, just get some worn out ones.
Old Jan 7, 2002 | 03:08 AM
89camaroRSV6's Avatar
does that kinda light hood really require a hood strut????
i thought even worn out hood struts could hold that...
Old Jan 9, 2002 | 12:53 AM
AmorgetRS's Avatar
Unless you have some really cheap or lightweight hood you can use stock hood shocks. I have two Fiberglass hoods and know others w/ Fiberglass hoods, and we all run stock shocks. Mine are both from ASCD, so I can't really say about any other company, but my ASCD SS hood has been using stock shocks for ~2 years w/ no problems.
Old Jan 9, 2002 | 11:59 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
my ascd bb stinger hood is fiberglass and i used new struts on it (they were replaced when i had my old hood, then i switched to the new hood) and it works just fine.
Old Jan 10, 2002 | 02:10 PM
TBIfly's Avatar
FIBERGLASS HOOD STRUTS!!!!
I posted this exact topic a week ago....and i have those hood struts/supports/lifts!!!!
Thanks to somebody who directed me to a website, i tracked em down!!
OK to all of you who have those fiberglass hoods and dont want to install a prop-rod, or use a telescoping pole...go to:
http://www.auto-parts-for-less.com and do the search for 83 Camaro
hood supports....or you can do it the easy way and call
(619) 460 1311...ask for:
pt# 14045326 you'll need 2 of these....i just put em on today and i have pre-come!!! sorry for the lack of class in that statement but its the only way I could adequately describe my excitement.
the list price is about $39 on my invoive but it mentions the web price to be 30% cheaper.....just check thru the website if it matters.
These are considerably smaller than any other hood support you've ever seen and they work perfectly, after the hood is a foot from the latch the struts start to aid push it up....no concerns about it falling, works like a champ!...i have one of the fiberglass hoods that already has the prongs/rods that stick from the hood-hinge that the struts go on..i only need to fashion a pin/retainer for it (do not buy the retainers that are on that site as they didnt fit the hoodsupports...im referring to #14036396
any Q's? grab my attention
Old Jan 10, 2002 | 09:59 PM
AmorgetRS's Avatar
Yeah, why do most autopart stores list the part # for the 83 "fiberglass" hood struts and same as the normal metal ones?
Old Jan 12, 2002 | 11:57 PM
toosloz's Avatar
i am using the steel one without any problems
Old Jan 13, 2002 | 10:51 AM
ONEFINE8T9's Avatar
becouse in 83 there was a factory fiberglass hood on the camaro
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
