large pin t-top
Old Sep 12, 2018 | 04:09 PM
leakman's Avatar
large pin t-top
i have a 1992 formula w/large pin t-tops. i know the large pin is a cover over a small pin. i am missing the cover on one of the pins and wondering where i can get one and how to install it if possible
Old Sep 13, 2018 | 10:28 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: large pin t-top
https://www.ebay.com/itm/1989-92-Camaro-Firebird-T-Top-Pin-Rebuild-Kit-8pc/351857320579?fits=Year%3A1992%7CModel%3ACamaro&epid=19010201035&hash=item51ec54a283:g:vd8AAOSwYIxX7WYi&vxp=mtr
Edit: here's just two of them for $13: https://www.ebay.com/itm/NEW-REPLACE...!US!-1&vxp=mtr
You'll need to take the t-top latch off, and also the trim panel on the t-top to access the pins. I believe the handle is held on with a torx screw (T15? T20? T25?), trim panel is held on with phillips head screws I believe. There should be a small c-clip that holds the plastic pins onto the rods, just remove it with a flat blade screwdriver, and prepare for the spring and pin to go flying when you get the clip out as they're pre-loaded. This is also a good opportunity to take some white lithium grease and coat the latch with it for smoother operation. Installation is opposite of the removal, you'll just need to hold the tension on the spring with one hand while you work the c-clip back on with your other hand.
Old Sep 13, 2018 | 01:01 PM
leakman's Avatar
Re: large pin t-top
thanx for the help
Fechin
Mar 1, 2018 10:51 AM
1Aauto
Sponsored Vendors
Jun 8, 2017 11:06 AM
1Aauto
Sponsored Vendors
Oct 6, 2016 08:26 AM
