Inner window felts hardware??
Old Jan 9, 2019 | 12:06 PM
03glide's Avatar
Car: 84 Z28
Transmission: auto
What hardware are you using to secure new inner window felts to the door panels? I tried some plastic rivets that failed. Aluminum rivets stuck out too far on the back side. I now have some small machine screws that might work. I was wondering what others are using.
Old Jan 9, 2019 | 06:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Inner window felts hardware??
I used rivets, i dont think there was any metal in the way when re-installed to interfere with fitment. You could also drill a new location if there is fitment issues.Did you try a shorter rivet?
Old Jan 9, 2019 | 10:58 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Screws.
Old Jan 9, 2019 | 11:00 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
1/4 inch self tappers. Take a couple quarters to the hardware store and grab a lifes worth.
Old Jan 10, 2019 | 08:08 AM
03glide's Avatar
Car: 84 Z28
Transmission: auto
Thanks for the info.
Old Jan 14, 2019 | 01:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I used large copper staples a few times, the kind you would find holding a large appliance box together. Works great,.... easy to remove if needed, will never rust, and will not interfere with anything when installed.
tom3
Feb 12, 2007 07:32 PM
blyth18md
Sep 19, 2004 06:50 PM
tom3
Jul 2, 2004 11:49 PM
omnipotentgoku
Mar 18, 2004 10:40 AM
omnipotentgoku
Mar 6, 2003 07:10 PM
