86 T/A How to repair ground effect mounting studs?
Old Jan 14, 2019 | 11:02 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Some of the studs snapped when attempting to get the nuts off the ground effects when disassembling my T/A. Are there any suggestions of good ways to fix them? Not sure if drilling out the old ones and possibly threading in some new studs would hold or not if some two-part epoxy was used.
Suggestions?
Old Jan 14, 2019 | 03:25 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: 86 T/A How to repair ground effect mounting studs?
on my '84 we ended up fabricating new brackets as most of the threaded studs snapped during removal. not sure if the '86 mounting brackets are the same. here's the post in my build thread:
https://www.thirdgen.org/forums/memb...ml#post5891099
Old Jan 15, 2019 | 03:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You can drill out the old stud and weld in another, or drill out the old one, tap the hole and screw in a bolt, or just put a bolt in and use a retaining clip to hold the bolt in the hole so it doesn't fall out when you mount it, some wire will work to hold it in too
Old Jan 15, 2019 | 03:39 PM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
battmann, first off, very nice build.
I should probably clarify that the studs that broke aren't the studs on the metal brackets that hold the smaller pieces on. Rather, these are the studs that are mounted in the door finishing effects. These are almost like a plastic type material and seem to just be pressed into the the piece that mounts to the door. I believe you actually buy re-pops of all the metal brackets, and I could make those myself to be honest.
Thanks for the input so far.
Old Jan 15, 2019 | 04:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Need a picture, but you might be able to buy the plastic stuff from clipsandfasteners.com
Old Jan 20, 2019 | 01:40 AM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
They sell them brand new on rockauto.com
Old Feb 11, 2019 | 03:37 AM
caged91's Avatar
Car: 1986 trans am
Engine: Doing 94 vette LT 1 swap right now
Transmission: need a t56
Axle/Gears: M78(9 bolt)mace locker,3.70
You can remove all the studs and replace them with a 1/4-20x 1 1/5" in length.simply remove the studs,run a 1/4-20 tap in the hole to clean it up a little.then use a 2 part panel bonding adhesive ( such as lord fusor's 208B panel bonding adhesive or equivalent) to "glue" the bolts into there new home. You can then cut the head of the bolt off making it a "stud". Very simple,no need to go buy some aftermarket crap thats not going to fit without more work...
Huffs_91_RS
Exterior Parts Wanted
Apr 6, 2017 05:18 PM
Firechicken86
Nov 11, 2013 05:32 PM
knightinblackar
Apr 22, 2010 04:54 AM
Roc Me 2
Nov 16, 2008 11:22 AM
Nightcruzer
Aug 25, 2006 01:49 PM
