Keys stolen. Need to replace key lock cylinder to hatch
My keys got stolen not too long ago. I was able to replace the steering wheel key lock cylinder by pulling the wheel off. But how do I get to the key lock cylinder to the hatch in the back?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Keys stolen. Need to replace key lock cylinder to hatch
You have to remove the plastic panel in the back.From there look behind the hatch motor/latch.You should see the lock cylinder with a clip holding it in place.remove that clip at the lock should pull off.If you've ever looked/removed the lock on the door.There is a similar clip holding it on.
Car: '89 Firebird
Engine: 7.0L
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
DR.K.
