door latch rubber, where should it be?
Old Aug 19, 2019 | 08:33 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
it appears the door latch should have a rubber coating, but what about the cavity where the latch is located? should there also be rubber in the cavity? i found decomposed rubber/plastic in the cavity. not certain what it was
yes, rubber here for sure
but what about down in that cavity?
Old Aug 20, 2019 | 06:57 AM
Drew's Avatar
Re: door latch rubber, where should it be?
Lots of grease mostly.
Old Aug 20, 2019 | 09:02 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just rubber/plastic around the "hook" part.
Old Aug 20, 2019 | 09:10 AM
LiquidBlue's Avatar
Transmission: MD8
thanks for the response guys. hmmmm, I guess that could have been dried up old grease that was in the cavity
Old Aug 24, 2019 | 01:48 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There is a plastic block in the cavity (arrow).Just behind the steel piece in front of the arrow.White or sometimes black in color.Its where the torx head on the striker stops on, i believe.
Old Aug 27, 2019 | 09:17 AM
LiquidBlue's Avatar
Transmission: MD8
Happen to have any photos you can share?
Old Aug 27, 2019 | 09:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
None of my own, but here's a couple.Visible here in white.Though ive seen them in black.They keep the striker from rattling i believe.Your looks like its missing, hard to tell though.
Some have nubs to hold them in place, but some dont use em.
rcdreamer
Nov 2, 2020 11:34 AM
evilemokid94
Jun 9, 2011 10:48 PM
dirtpoor1
Dec 27, 2009 02:54 PM
91-GasGuzlinZ-28
May 1, 2002 04:08 PM
camaro_5.7L_350
Jul 16, 2001 06:24 PM
