Headlights/BLUE
Old Jan 13, 2002 | 12:08 PM
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
Headlights/BLUE
Is there a company that's makes the "blue" halogen headlights for a 3rd gen?
I'm sure this question is beat into the ground, but can't seem to find in archives.
thanx
80's AL
80' Berlinetta
89' RS
Old Jan 13, 2002 | 12:21 PM
MNformula350's Avatar
Checker auto parts has hte sylvania cool blue headlights.
For a friebird the part# is 6054CB
I don't remember what the Camaro one is right off the top of my head,but it would be the regular replacement # with a CB after it.
Old Jan 13, 2002 | 12:33 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have those Cool Blue lights on my T/A. Not really blue, but a really bright white, I like them.
Old Jan 13, 2002 | 01:09 PM
80's Al's Avatar
Engine: 383ci
89245107
So....I'm sure @ most parts stores, I can just look for Sylvania, CB after the P# , and they should be able to find it. being I have a Camaro, I'll need high beams too...
THANX
80's AL
80' Berlinetta
89' RS
Old Jan 13, 2002 | 04:56 PM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
http://www.procarparts.com/store/dis...d=DIAM-XENCONV
this is the link to get the kit. Include the whole headlamp assembly with a diamond cut lens and gas charged hyper ****e bulbs
Old Jan 13, 2002 | 06:09 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Or you can try ebay!! http://cgi.ebay.com/ebaymotors/aw-cg...item=600465137
Old Jan 13, 2002 | 07:22 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Rather then dealing with ebay you can just go to: www.prostreetlighting.com to get the diamond cut housing and a set of Tucan industries blue H4 Exnon placement bulbs. I got my set for $70.00 on ebay, but if you call them direct they may give you a cheaper price. They look really nice too.
Note:These are blue in person.
Attached Thumbnails Headlights/BLUE-dcp_0004.jpg
Old Jan 13, 2002 | 07:25 PM
fiream's Avatar
Engine: 400HP 350
heres another
Attached Thumbnails Headlights/BLUE-dcp_0005.jpg
Old Jan 13, 2002 | 08:21 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
hey guys, on was on the market for this headlight conversion kit, but when looking at the 2 different websites given by FlyinLow89 and fiream- i noticed that there seems to be a size difference-prostreet lighting only gives the size 5 X 7 inch diamond cut sealed beam housings, while procarparts gives numerous sizes for the H4 replacement bulb-that is the replacement bulb for a firebird-H4666 right??? because they say it replaces "H6054"???
i'm a little confused! can a firebird fit a 5x7 or 6x8???-does it matter?!?!?
Old Jan 13, 2002 | 10:32 PM
fiream's Avatar
Engine: 400HP 350
My kit fits fine
Old Jan 13, 2002 | 10:58 PM
91fbirdgta's Avatar
fiream, i'm sure it does fit fine-but what is the actual measurement of the kit u have on now? i measured my bulb casing and it was
4 1/2 x 6 1/2-but like i said the kits on those websites have diff. measurements then that like, 5x7 and 6x8, no 4 1/2 x 6 1/2, see my point!
and it does come w/ the casing right!?!? and are the lights blue???
Old Jan 14, 2002 | 12:56 AM
fiream's Avatar
Engine: 400HP 350
I have the 5x7 kit, and if fits right into place. The 6x8 is way to big and will not fit, some mods would be nessesarry. the bulbs are blue that i have, you can really tell in the picture. The bulbs are from Tucan Industries they are H4 55w/65ww and they are Exnon bulbs.
What you get in the kit is the 5x7 casing thats diamond cut glass, a rear rubber boot cover to keet water out, and the bulbs.
Old Jan 14, 2002 | 06:19 AM
80's Al's Avatar
Engine: 383ci
That ProStreetLighting looks like the way to go.
Thanks for all the help.
90's AL
80' Berlinetta
89' RS
Old Jan 14, 2002 | 12:42 PM
jm91rs's Avatar
I saw a kit for hyper white on ebay once before. It somehow converted the sealed light to something with a replacable bulb.
